> Bench testing 1973 Intermittent Wiper, Confusion around wiper behavior
GeorgeKopf
post Jun 15 2025, 11:48 AM
I'm bench testing my wiper motor without the intermittent wiper relay in the circuit.
1. Connect ground.
2. Apply power to red/white or red/black (53a)
(wipers park at the down position)
3. Apply power to black/blue (53)
(wipers run at the slow speed; when black/blue is disconnected the wipers park)
4. Apply power to black/purple (53b)
(wipers run at fast speed; when black/purple is disconnected the wipers park)
5. Apply power to green/white (31b)
(nothing happens)
Shouldn't this initiate one cycle of the wiper arms, after which they should park?
My understanding is that the wiper relay sends a periodic pulse through the green/white wire to trigger one cycle (one wipe).
If I apply power to red/white(53a), black/blue(53) and green/white(31b) and then remove the black/blue(53), leaving power to red/white(53a) and green/white(31b), the motor continues to run with a tiny pause where it would normally park. It seems that once it gets started the green/white(31b) prevents it from parking. If I remove power to the green/white(31b), the motor parks and cannot be restarted with just power to green/white(31b).
With the intermittent relay connected, the behavior is exactly the same, BUT I hear the relay chirp in between each cycle.
I'm hoping that my wiper motor is working correctly and that my relay is bad.
Am I testing this wrong?
Thanks.
George
ClayPerrine
post Jun 16 2025, 06:59 AM
Did some checking online. Here are the connection directions.
C) Locate the 4 wires on the wiper motor (Fig. 8)
The wiper motor wires are color coded as follows: red/black, green/white, black/blue,
black/purple
D) Insert the relay harness wires in line with the original motor wires (Figs. 7, 9)
1) Remove the red/black wire from the wiper motor. Attach the relay red wire to the
motor (it has a double connector) then put the red/black back on the second pin.
2) Remove the green/white wire from the motor and attach it to the relay blue/black wire
(male connector, inside the box housing)
3) Take the relay green/white wire and attach it to the previous original green/white
connector on the wiper motor
4) Insert the brown/black wire into the only empty connector in the relay socket
5) Attach the relay brown wire to the wiper motor ground
From https://bowlsby.net/914/WiringHarnesses/doc...nstructions.pdf
- Lo-Fi Version Time is now: 13th July 2025 - 03:42 PM
