> Wheel bearing washer test question, How easy should it move?
emerygt350
post Jun 16 2025, 05:56 PM
Just curious. I did my fronts last week and rechecked them today. How easily should the washer move? I can make it move easily when I pry against the side of the hub with a screw driver. Is that right or should it be easy to move without prying? And does it really matter that much? I am from the old school "tighten til it's hard to rotate and the back it off half a turn" world.
Superhawk996
post Jun 16 2025, 07:31 PM
Gonna put this up for additional guidance.
https://www.timken.com/wp-content/uploads/2...-Brochure-1.pdf
post Jun 16 2025, 07:51 PM
Resident German
QUOTE(Superhawk996 @ Jun 16 2025, 06:31 PM) *
Yupp, just like i said, tighten by hand, give it a whack, done ...
Superhawk996
post Jun 16 2025, 08:07 PM
QUOTE(SirAndy @ Jun 16 2025, 09:51 PM) *
Most OE’s long ago moved away from taper roller bearings due to the inherent “vagueness” of their adjustment.
No matter how well documented and how many words are on paper it still comes down to a certain degree of familiarity and feel.
There is also the weirdness that the rear ball bearings must have significant preload on them to live while taper roller bearings are basically the opposite - preferring no preload or only slight preload.
If you’ve got the feel. . . You’ve got the feel.
- Lo-Fi Version Time is now: 19th June 2025 - 01:56 PM
