 Forum Rules Classified Rules!
> 74 2L $4500 for everything, Several good parts to be had.
PlantMan
post Jun 17 2025, 08:39 AM
UPDATED:
Hello,
I picked up this car in 2014 and about the only thing I have done is strip a majority of it down except for the front suspension and started cutting out the rust from the engine compartment. I have boxed up all the parts and everything goes with the car, minus the front windshield which was cracked already and the fuel injectors which were tested and found to leak.
Cons:
The car need rust repair as you can tell by the photos.
Car did have AC so need to consider hole in the Frunk. AC stuff that I do have go with the car.
Pros:
The interior was in good shape, maybe 7 out of 10.
2.0l with original fuel injection that was running before I started stripping the car (I got running when I purchased the car).
Transmission seems to be OK
Numbers matching.
I have $2100 in RD replacement metal:
-Front floor section
-Lower fire wall
-Cross member support
-Outer Longs for both side with jack support
-Inner and other wheel house supports
-Engine tray for passenger side
-Misc other pieces
I also have a replacement cowl section for under the windshield.
Stainless steel heat exchangers
A very nice Banana exhaust
Trying to run 3 business is not allowing me to do this car which is a bummer ...... I will replace it in the future with another project.
Offered here only to 914World folks first.
Car is in Mission Viejo, CA
Will consider:
-$1750 for the car.
-$1500 for the RD sheet metal
-$1250 for the SS exchangers and muffler
Also see my Build Thread below.
Text/Call Kevin @ (949)370-5821
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
PlantMan   74 2L $4500 for everything   Jun 17 2025, 08:39 AM
PlantMan   Updated with images above. Pricing for selected it...   Aug 23 2025, 10:33 PM
PlantMan   Exhaust Items SS Exchangers. I purchased these l...   Sep 3 2025, 10:18 PM
PlantMan   Bump   Jun 25 2026, 12:39 PM
4 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
1 Members: Tabsocal
- Lo-Fi Version Time is now: 25th June 2026 - 05:23 PM
