> Calling for a 17mm Master Cylinder, Don't like the 19mm!!
Artfrombama
post Jun 17 2025, 11:32 AM
Artfrombama
Replaced the OE 17mm that came on my 74 because it was leaking out of the rear. Replaced it with the 19mm that is currently offered as a replacement.
Not happy with the increased pedal pressure required to stop the car, almost scary in a panic situation. No pedal modulation.
I would like to return to a 17mm unit but there seems to be no more out there, does anyone have a source? Is someone in the parts supply chain able to reproduce these parts reasonably?
Thanks!
914Sixer
post Jun 17 2025, 04:40 PM
My car has a one year only 1969 911T 20mm MC used for solid rotors front and back. Really high pressure for -4 brakes. Up grading to Brembo's and -6 rears. Going to see how it works. Have NOS ATE 19mm for back up.
I find 17mm MC from time to time but VERY rare.
porschetub
post Jun 17 2025, 09:40 PM
QUOTE(914Sixer @ Jun 18 2025, 10:40 AM) *
running 19mm with Brembo 4 pots front and rear off 951 ,found it stops great for non-servo system so you should be fine when you upgrade.
Artfrombama   Calling for a 17mm Master Cylinder   Jun 17 2025, 11:32 AM
rjames   Replaced the OE 17mm that came on my 74 because i...   Jun 17 2025, 11:40 AM
Shivers   I did the 19 mm M/C and some of Eric Shea’s stic...   Jun 17 2025, 11:54 AM
mepstein   I’m with you. I’ve tried both and prefer a 17m...   Jun 17 2025, 11:55 AM
Artfrombama   I’m with you. I’ve tried both and prefer a 17...   Jun 17 2025, 01:07 PM
StratPlayer   Getting ready to install a 23mm MC, recommended by...   Jun 17 2025, 12:53 PM
bdstone914   Getting ready to install a 23mm MC, recommended b...   Jun 17 2025, 10:17 PM
infraredcalvin   Getting ready to install a 23mm MC, recommended ...   Jul 8 2025, 08:23 PM
Jack Standz   We have at least two failed 17mm master cylinders/...   Jun 17 2025, 01:45 PM
914werke   Agree that it would be best if a rebuild kit coul...   Jun 17 2025, 02:05 PM
mepstein   17mm rebuild kits are a thing of the past. Im surp...   Jun 17 2025, 02:08 PM
914Sixer   My car has a one year only 1969 911T 20mm MC used ...   Jun 17 2025, 04:40 PM
porschetub   My car has a one year only 1969 911T 20mm MC used...   Jun 17 2025, 09:40 PM
914xr75   I just purchased a fresh 17mm ATE mc at Pelican la...   Jun 17 2025, 06:23 PM
904svo   Replaced the OE 17mm that came on my 74 because i...   Jun 17 2025, 06:27 PM
bkrantz   The 17 mm MC has a cross section area of about 227...   Jun 17 2025, 08:50 PM
Jack Standz   I just purchased a fresh 17mm ATE mc at Pelican l...   Jun 18 2025, 02:12 AM
Jack Standz   17mm rebuild kits are a thing of the past. Im sur...   Jun 18 2025, 02:17 AM
bdstone914   Replaced the OE 17mm that came on my 74 because i...   Jun 18 2025, 03:23 AM
Artfrombama   Replaced the OE 17mm that came on my 74 because ...   Jun 18 2025, 11:55 AM
930cabman   somebody has the technology to fabricate these :i...   Jun 18 2025, 12:07 PM
Artfrombama   somebody has the technology to fabricate these :...   Jun 18 2025, 12:37 PM
rjames   somebody has the technology to fabricate these ...   Jun 18 2025, 01:56 PM
930cabman   [quote name='Artfrombama' post='3210825' date='Ju...   Jun 18 2025, 05:02 PM
Artfrombama   [quote name='Artfrombama' post='3210825' date='J...   Jun 19 2025, 09:39 AM
mepstein   [quote name='930cabman' post='3210849' date='Jun ...   Jun 19 2025, 11:01 AM
emerygt350   [quote name='930cabman' post='3210849' date='Jun...   Jul 7 2025, 07:42 PM
914xr75   Call pelican. They actually took a week to get my ...   Jun 18 2025, 01:09 PM
pfreiburger   Here, try this, a brand new ATE 17mm cylinder (cle...   Jun 19 2025, 12:27 AM
914Sixer   Another ebay idiot LISTING THE WRONG PART.   Jun 19 2025, 08:25 AM
Highland   I saw this on Pelican's site: https://www.pel...   Jul 7 2025, 07:00 PM
anderssj   I saw this on Pelican's site: https://www.pe...   Jul 8 2025, 11:16 AM
Chris914n6   I've had issues with rockauto after it changed...   Jul 8 2025, 02:27 AM
mepstein   I've had issues with rockauto after it change...   Jul 8 2025, 05:26 AM
friethmiller   Dumb question here. Would a larger 23mm MC be ok w...   Jul 8 2025, 09:36 AM
Superhawk996   Dumb question here. Would a larger 23mm MC be ok ...   Jul 8 2025, 09:52 AM
Superhawk996   For comparison- the 19mm master cylinder is about ...   Jul 8 2025, 09:54 AM
friethmiller   Bad plan. Would result in an 83% increase in p...   Jul 8 2025, 12:33 PM
Mitox   Or, if you can get a loan, there is this rebuild k...   Jul 8 2025, 08:03 PM
Literati914   Are Centric MC’s out of the question?: https://...   Jul 9 2025, 10:16 AM
- Lo-Fi Version Time is now: 15th April 2026 - 09:02 PM
