| Artfrombama |
Jun 17 2025, 11:32 AM
Artfrombama ![]() ![]() Group: Members Posts: 446 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
Replaced the OE 17mm that came on my 74 because it was leaking out of the rear. Replaced it with the 19mm that is currently offered as a replacement.
Not happy with the increased pedal pressure required to stop the car, almost scary in a panic situation. No pedal modulation. I would like to return to a 17mm unit but there seems to be no more out there, does anyone have a source? Is someone in the parts supply chain able to reproduce these parts reasonably? Thanks! |
| bdstone914 |
Jun 18 2025, 03:23 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,289 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Replaced the OE 17mm that came on my 74 because it was leaking out of the rear. Replaced it with the 19mm that is currently offered as a replacement. Not happy with the increased pedal pressure required to stop the car, almost scary in a panic situation. No pedal modulation. I would like to return to a 17mm unit but there seems to be no more out there, does anyone have a source? Is someone in the parts supply chain able to reproduce these parts reasonably? Thanks! It should not be that hard to stop with a 19mm. What pafs are you using? Do you have a used 17mm master? Sometimes rebuild kits pop up. The seals are a common hydraulic style seal. I have never tried to source them. I have had a couple NOS 17mm masters that I have sold. |
Artfrombama Calling for a 17mm Master Cylinder Jun 17 2025, 11:32 AM
rjames
Replaced the OE 17mm that came on my 74 because i... Jun 17 2025, 11:40 AM
Shivers I did the 19 mm M/C and some of Eric Shea’s stic... Jun 17 2025, 11:54 AM
mepstein I’m with you. I’ve tried both and prefer a 17m... Jun 17 2025, 11:55 AM
Artfrombama
I’m with you. I’ve tried both and prefer a 17... Jun 17 2025, 01:07 PM
StratPlayer Getting ready to install a 23mm MC, recommended by... Jun 17 2025, 12:53 PM
bdstone914
Getting ready to install a 23mm MC, recommended b... Jun 17 2025, 10:17 PM
infraredcalvin
Getting ready to install a 23mm MC, recommended ... Jul 8 2025, 08:23 PM
Jack Standz We have at least two failed 17mm master cylinders/... Jun 17 2025, 01:45 PM
914werke Agree that it would be best if a rebuild kit coul... Jun 17 2025, 02:05 PM
mepstein 17mm rebuild kits are a thing of the past. Im surp... Jun 17 2025, 02:08 PM
914Sixer My car has a one year only 1969 911T 20mm MC used ... Jun 17 2025, 04:40 PM
porschetub
My car has a one year only 1969 911T 20mm MC used... Jun 17 2025, 09:40 PM
914xr75 I just purchased a fresh 17mm ATE mc at Pelican la... Jun 17 2025, 06:23 PM
904svo
Replaced the OE 17mm that came on my 74 because i... Jun 17 2025, 06:27 PM
bkrantz The 17 mm MC has a cross section area of about 227... Jun 17 2025, 08:50 PM
Jack Standz
I just purchased a fresh 17mm ATE mc at Pelican l... Jun 18 2025, 02:12 AM
Jack Standz
17mm rebuild kits are a thing of the past. Im sur... Jun 18 2025, 02:17 AM
Artfrombama
Replaced the OE 17mm that came on my 74 because ... Jun 18 2025, 11:55 AM
930cabman somebody has the technology to fabricate these :i... Jun 18 2025, 12:07 PM
Artfrombama
somebody has the technology to fabricate these :... Jun 18 2025, 12:37 PM
rjames
somebody has the technology to fabricate these ... Jun 18 2025, 01:56 PM
930cabman
[quote name='Artfrombama' post='3210825' date='Ju... Jun 18 2025, 05:02 PM
Artfrombama
[quote name='Artfrombama' post='3210825' date='J... Jun 19 2025, 09:39 AM
[quote name='930cabman' post='3210849' date='Jun ... Jun 19 2025, 11:01 AM
emerygt350
[quote name='930cabman' post='3210849' date='Jun... Jul 7 2025, 07:42 PM
914xr75 Call pelican. They actually took a week to get my ... Jun 18 2025, 01:09 PM
pfreiburger Here, try this, a brand new ATE 17mm cylinder (cle... Jun 19 2025, 12:27 AM
914Sixer Another ebay idiot LISTING THE WRONG PART. Jun 19 2025, 08:25 AM
Highland I saw this on Pelican's site:
https://www.pel... Jul 7 2025, 07:00 PM
anderssj
https://www.pe... Jul 8 2025, 11:16 AM
Chris914n6 I've had issues with rockauto after it changed... Jul 8 2025, 02:27 AM
I've had issues with rockauto after it change... Jul 8 2025, 05:26 AM
friethmiller Dumb question here. Would a larger 23mm MC be ok w... Jul 8 2025, 09:36 AM
Superhawk996
Dumb question here. Would a larger 23mm MC be ok ... Jul 8 2025, 09:52 AM
Superhawk996 For comparison- the 19mm master cylinder is about ... Jul 8 2025, 09:54 AM
friethmiller
Bad plan.
Would result in an 83% increase in p... Jul 8 2025, 12:33 PM
Mitox Or, if you can get a loan, there is this rebuild k... Jul 8 2025, 08:03 PM
Literati914 Are Centric MC’s out of the question?:
https://... Jul 9 2025, 10:16 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 08:59 PM |
