> Rear Red Turnsignals Double as Brakes, Increase Brake Lights with Rear Turnsignals
Spoke
post Jun 17 2025, 01:27 PM
Jerry
Engelbert designed a solution for the 911 to allow the rear turnsignal to double as brake lights for a larger brake footprint. I believe he is planning to market it for the 911 guys. Because of the layout of the 911 rear light housing, to install the module in the housing, the housing has to be removed and opened up.
I thought this would work well for the 914 and should be easy to install as access to the rear housing and wires is in the trunk. Engelbert was ok with me basically copying his solution.
Here's a link to his 911 solution:
rothaus (Engelbert) 911 RTS to Brakes
The RTS-Brake module would reside below each rear light housing. One for each side. Here's the module being tested on the bench.
https://www.youtube.com/watch?v=i5h_pG7AQ9A
The module has 6 wires. Brake-in, Brake-out, RTS-in, RTS-out, and 2 grounds. The wires have QC connectors and go between the OEM wiring and the light housings.
The IN wires have male connectors and the OUT wires have female connectors.
On each side, pull the brake, RTS, and GND wires from the housing. The wires connect to the IN wires and the OUT wires goes to the housing.
On my '71, the RTS QC connectors don't have insulation so a short piece of heat shrink provides the insulation.
Once the RTS connectors are insulated, pull one wire at a time and install.
Here are the modules in action on my 914. My 914 is set up to always have the running lights on with the ignition.
https://www.youtube.com/watch?v=RHFrilGntQM
I built an extra set if someone would like to try them out. If folks are interested, I'll be selling these for $45/pair.
Spoke
post Jun 18 2025, 07:40 AM
Jerry
Here's a connection diagram for these RTS-Brake modules. Connecting these modules is straightforward. Pull one wire at a time and plug the OEM wire into the corresponding module wire color and wire color to the housing.
All the connection information and OEM wire colors were used from Jeff Bowlsby's diagram:
Spoke   Rear Red Turnsignals Double as Brakes   Jun 17 2025, 01:27 PM
FlacaProductions   Hey Jerry - of course I'd love to try em out b...   Jun 17 2025, 03:52 PM
slowrodent   Very very practical and very good looking.... Look...   Jun 17 2025, 04:00 PM
mepstein   Your products (and support) are always top notch. ...   Jun 17 2025, 04:38 PM
Spoke   Your products (and support) are always top notch....   Jun 17 2025, 05:13 PM
Cairo94507   Boy... I run the Euro rear lenses on my 6 but real...   Jun 17 2025, 04:54 PM
Olympic 914   I will also be in for a set. When can we place a...   Jun 17 2025, 05:16 PM
Spoke   I will also be in for a set. When can we place ...   Jun 17 2025, 07:12 PM
JmuRiz   Great idea, I’ll have to add to my parts stash   Jun 17 2025, 07:16 PM
Spoke   Here's a connection diagram for these RTS-Brak...   Jun 18 2025, 07:40 AM
ValcoOscar   Just terrific... I'm in for TWO(2) sets. :be...   Jun 18 2025, 07:53 AM
jim_hoyland   Nice upgrade Jerry, I’ll order a set :) PM sent ...   Jun 18 2025, 10:02 AM
gonzo54   @Spoke , I have your LED Brake Boards on my car bu...   Jun 18 2025, 10:54 AM
Spoke   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jun 18 2025, 12:35 PM
JeffBowlsby   Do I see piggyback terminals on the left side hous...   Jun 18 2025, 02:52 PM
Spoke   Do I see piggyback terminals on the left side hou...   Jun 18 2025, 05:48 PM
Stratfink   Ordered this morning along with the brake, turn si...   Jun 19 2025, 11:10 PM
- Lo-Fi Version Time is now: 26th August 2025 - 09:35 PM
