> Fuel filler rust
Amphicar770
post Jun 10 2025, 03:38 PM
A few years back, before repro units were available, I had my tank restored with a process called Gas tank Renu. At the same time, I had the fuel filler assembly blasted and powder coated.
Last week, as I went to add fuel for first Summer jaunt, I noticed lots of rust and flaking in the fuel filler neck. I just removed that as I was also concerned if tank sealant had failed.
Good news is that the tank sealant remains rock hard. Bad news is that The filler is worse than I first noticed. I will definitely need to clean out some of the crud from that which is now in the tank.
I think the fuel cap spring may not have helped the filler neck coating. Is the spring even needed?
Attached are photos of filler assembly. I can blast it again, but then what? Should I try having it powder coated again, perhaps it was done poorly last time. Should I instead paint it with an epoxy based paint? Other?
dtmehall
post Jun 13 2025, 09:02 PM
here's an off the wall question
do you use pure ethanol fuel?
Amphicar770
post Jun 19 2025, 06:31 AM
QUOTE(dtmehall @ Jun 13 2025, 10:02 PM) *
Actually, most times I go 20 miles out of my way to get ethanol free fuel. Of course, you can never be certain about what is actually coming out of the pump.
- Lo-Fi Version Time is now: 12th July 2025 - 02:37 AM
