> 70-71 911 box for 914-6 conversion, Looking for confirmations...
Montreal914
post Jun 18 2025, 11:42 PM
I was on the fence between using a 915 or a 901 style box for my 3.2 six conversion until recently where I read a comment from @ClayPerrine that the 70-71 911 (911/01) box was set up with the pull style clutch.
What I have in hand for my conversion:
- 911/01 box
- Three side shift 914 gearboxes
- Various gear set ratios to have fun! (IMG:style_emoticons/default/driving.gif)
- 100mm coarse spline output flanges to go with my 944 CVs
My plan was to use:
- Stock 3.2 flywheel clutch assembly currently on the engine
- Get a 70-71 release bearing
- Get a 72(?) clutch cable that would be straight pull (no cable pulley)
I was going to use the 911/01 bits, flip the R&P, reset the pinion depth, use complementary 914 side shift trans cover, shifting, etc
What I think I am undestanding from this thread linked below is:
- The pull clutch setup works well
- Yes, it can be tricky to get the release fork mating to the bearing upon assembly
- I should not use the 3.2 PP as it will pull the fork pivot bolt?
- I should use a 2.2 PP?
- What disk should I be using?
- Does this simply bolts on the 3.2 flywheel?
- Is the clutch pivot shaft/arm at the pedal cluster different than 914, should I replace it? I just rebuilt my pedal cluster.
Any inputs appreciated (IMG:style_emoticons/default/beerchug.gif)
http://www.914world.com/bbs2/index.php?sho...267204&st=0
post Jun 19 2025, 06:35 AM
914-6 GT in waiting
Problem I think about is you need two trans to make one. An early 911 trans core is usually $1500, mare if it’s in good shape. Then you need to rebuild the parts from both into one trans.
Why not just use the stock trans, buy the clutch conversion kit from KEP for ~$650 or whatever the going rate these days and call it done?
sixnotfour
post Jun 19 2025, 07:37 AM
QUOTE(mepstein @ Jun 19 2025, 06:35 AM) *
old school cool...but not worth the effort..IMHO.. at this point in time..
I have several , early all aluminum pressure pressure plates,,
and 911/01 boxes
But if you drive hard the anti rotation strap locations will break.. (IMG:style_emoticons/default/popcorn[1].gif)
And its still a 901..
- Lo-Fi Version Time is now: 24th August 2025 - 04:04 PM
