> 70-71 911 box for 914-6 conversion, Looking for confirmations...
Montreal914
post Jun 18 2025, 11:42 PM
I was on the fence between using a 915 or a 901 style box for my 3.2 six conversion until recently where I read a comment from @ClayPerrine that the 70-71 911 (911/01) box was set up with the pull style clutch.
What I have in hand for my conversion:
- 911/01 box
- Three side shift 914 gearboxes
- Various gear set ratios to have fun! (IMG:style_emoticons/default/driving.gif)
- 100mm coarse spline output flanges to go with my 944 CVs
My plan was to use:
- Stock 3.2 flywheel clutch assembly currently on the engine
- Get a 70-71 release bearing
- Get a 72(?) clutch cable that would be straight pull (no cable pulley)
I was going to use the 911/01 bits, flip the R&P, reset the pinion depth, use complementary 914 side shift trans cover, shifting, etc
What I think I am undestanding from this thread linked below is:
- The pull clutch setup works well
- Yes, it can be tricky to get the release fork mating to the bearing upon assembly
- I should not use the 3.2 PP as it will pull the fork pivot bolt?
- I should use a 2.2 PP?
- What disk should I be using?
- Does this simply bolts on the 3.2 flywheel?
- Is the clutch pivot shaft/arm at the pedal cluster different than 914, should I replace it? I just rebuilt my pedal cluster.
Any inputs appreciated (IMG:style_emoticons/default/beerchug.gif)
http://www.914world.com/bbs2/index.php?sho...267204&st=0
Steve
post Jun 19 2025, 01:20 PM
Clay is running a boxster/cayman trans with his 4.0 motor. If they ever come out with a kit for the 3.2 or 3.6, this would be the way to go over the 915 trans. The newer borg warner design is way easier to shift than a 915 or 914 trans. I’m happy with my 915 trans and have no interest in converting to anything else.
- Lo-Fi Version Time is now: 24th August 2025 - 04:05 PM
