> Chances of fixing ECU issue by checking Ohm's etc ?, stock 1.7 D-jet ECU
Literati914
post Jun 17 2025, 09:27 AM
The problem - I have a stock 2.0L d-jet ECU that starts and runs my 1.7L engine just fine, though I suspect that the engine's running too rich with it .... and I've read of the wrong ECU causing hydro-lock to these engines. So, I'm kind of afraid to even start the engine on this ECU.
I purchased a used 1.7 ECU a few weeks back - $40 off the Samba but there were no guarantees as the guy said he purchased an old VW repair shop that it came out of and had no idea if it worked.
So, I vaguely remember a video posted (somewhere?) where the guy was diagnosing a no start issue by running through all the pins of the ECU and checking Ohm's, continuity etc. I can't find the video now unfortunately. I know there's a special D-jet testing machine - but would finding an off electrical value not allow for repair inside the ECU? I haven't opened this 1.7L unit up yet - it may have obvious damage. I was wondering if it's even worth breaking open?
Literati914
post Jun 17 2025, 10:59 AM
QUOTE(Superhawk996 @ Jun 17 2025, 11:39 AM) *
You need to figure out what 1.7L system you have
The 73’ 2.0l system did use the 1.7L ECU but with a unique MPS, CHT, and CHT resistor for the 2.0L
The other year 1.7l use different ECUs
Spend the time to understand that components your using and use the Anders part chart and compatibility matrix
Generally speaking parts are not mix and match
Yea, I did all that before purchasing the ECU from samba.. didn't just randomly buy an ECU. I got the 021 A / 013 unit for my '72/1.7 . I looked at components but will double check them. I got the hydro-lock comment from @Dave_Darling in a post he'd made several years back. .."I had a period where I was swapping ECUs to see if they had any effect on how the car ran. One of them did--it hydro-locked the motor with fuel! .."
ps - I can hear the fuel pump run for a second or so, with the 1.7 ECU as I should.
Dave_Darling
post Jun 19 2025, 11:20 PM
914 Idiot
QUOTE(Literati914 @ Jun 17 2025, 09:59 AM) *
One of the possible failure modes for the output stage in the ECU is that it "forgets" to turn the injectors off. So it tells them to open, and then just leaves them open. Ugly problem when it happens intermittently when trying to start. Would probably be a much worse problem if it happened at speed on the highway, though.
--DD
- Lo-Fi Version Time is now: 2nd April 2026 - 11:15 PM
