| Olympic 914 |
Jun 19 2025, 10:41 AM
![]() ![]() ![]() Group: Members Posts: 1,772 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
This winter I installed Koni Adj strut inserts in the front, and just left the alignment settings where they were at.
I borrowed a buddy's Camber/Caster gauge and decided to fine tune things today. Started out putting 185lbs in the drivers seat. (my weight) and then set the ride height all around. putting the front A-arms at level. Then went about checking the Camber. on the front they were only slightly different, So I set them both at -3 deg camber. Caster seemed OK at 6 deg. so I left it there. Rear camber is -2.5 deg (2. 30min?) on the right and -2.62 (2.37min) left. I really don't want to mess with this. It seems to handle pretty good. Is that too much front camber for a street car? I'm not really too worried about tire wear. |
| Geezer914 |
Jun 20 2025, 07:53 AM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,278 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
I am running negative 1.4 camber in front with 6° castor , 1/16 toe in. The rear is negative 1.5° camber and 0° toe.
Olympic 914 Too much front Camber ? Jun 19 2025, 10:41 AM
fiacra I don't know if this is of any help to you, bu... Jun 19 2025, 10:58 AM
dr914@autoatlanta.com 3 degrees neg in the front is outrageous, besides ... Jun 19 2025, 11:40 AM
Olympic 914
3 degrees neg in the front is outrageous, besides... Jun 20 2025, 09:11 AM
jd74914
Outrageous... :blink:
-3 is quite a bit for ... Jun 20 2025, 02:59 PM
stownsen914 -3 is a lot on a primarily street driven car. I do... Jun 22 2025, 08:38 AM
Dave_Darling For spirited street driving, I prefer about 0.5 de... Jun 19 2025, 11:46 PM
brant My street car around negative 1.5 in front
I’ve... Jun 20 2025, 09:02 AM
BillJ I have the same widths and don’t run that much c... Jun 20 2025, 12:55 PM
Olympic 914 Full disclosure...
Its not at -3deg. Whenever I w... Jun 22 2025, 09:34 AM
Dave_Darling If you set up a vertical line, you can measure fro... Jun 23 2025, 11:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 01:11 PM |
