| Olympic 914 |
Jun 19 2025, 10:41 AM
![]() ![]() ![]() Group: Members Posts: 1,772 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
This winter I installed Koni Adj strut inserts in the front, and just left the alignment settings where they were at.
I borrowed a buddy's Camber/Caster gauge and decided to fine tune things today. Started out putting 185lbs in the drivers seat. (my weight) and then set the ride height all around. putting the front A-arms at level. Then went about checking the Camber. on the front they were only slightly different, So I set them both at -3 deg camber. Caster seemed OK at 6 deg. so I left it there. Rear camber is -2.5 deg (2. 30min?) on the right and -2.62 (2.37min) left. I really don't want to mess with this. It seems to handle pretty good. Is that too much front camber for a street car? I'm not really too worried about tire wear. |
| BillJ |
Jun 20 2025, 12:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,355 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None
I have the same widths and don’t run that much camber on the race car. It is indeed a lot. I bet you will find turn in quicker and responsiveness better and you willhave a larger tire contact patch. With that much camber you are reducing how much of the tire you are using. You may have to get used to it as it may feel a little more darty but trust me that you should really max out at about 2 for street driving and even that is aggressive.
Olympic 914 Too much front Camber ? Jun 19 2025, 10:41 AM
fiacra I don't know if this is of any help to you, bu... Jun 19 2025, 10:58 AM
dr914@autoatlanta.com 3 degrees neg in the front is outrageous, besides ... Jun 19 2025, 11:40 AM
Olympic 914
3 degrees neg in the front is outrageous, besides... Jun 20 2025, 09:11 AM
jd74914
Outrageous... :blink:
-3 is quite a bit for ... Jun 20 2025, 02:59 PM
stownsen914 -3 is a lot on a primarily street driven car. I do... Jun 22 2025, 08:38 AM
Dave_Darling For spirited street driving, I prefer about 0.5 de... Jun 19 2025, 11:46 PM
Geezer914 I am running negative 1.4 camber in front with 6°... Jun 20 2025, 07:53 AM
brant My street car around negative 1.5 in front
I’ve... Jun 20 2025, 09:02 AM
Olympic 914 Full disclosure...
Its not at -3deg. Whenever I w... Jun 22 2025, 09:34 AM
Dave_Darling If you set up a vertical line, you can measure fro... Jun 23 2025, 11:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 01:14 PM |
