> Trailing Arm Install Questions, Camber Shim and Washer
DennisV
post Jun 20 2025, 07:06 PM
Is this the correct placement for the camber alignment shim on the rear trailing arm? it seems weird to me that it sticks off at the corner like that, but I can't find any other orientation that allow 3 bolt holes to line up.
Does the washer go on the trailing arm side of the body tab, as opposed to the nut side?
Thank you.
Ishley
post Jun 20 2025, 08:32 PM
Yes to both. The only thing I did different was to use locking nuts from
McMaster Carr. I found the inside nut would loosen as I drove the car… and this was recommended by others. I haven’t had the issue since I added these nuts.
I get under the car from time to time and just check that everything is still tight. Something to consider after you drive a bit. You’ll also want to get a wheel alignment.
https://www.mcmaster.com/product/93795A335
They are single use nuts… so I have a pack of 8 more if I ever need it.
DennisV
post Jun 21 2025, 04:58 AM
QUOTE(Ishley @ Jun 20 2025, 07:32 PM) *
Thank you for the confirmation and tip on the lock nuts.
- Lo-Fi Version Time is now: 1st July 2025 - 11:01 AM
