DennisV |
Senior Member ![]() ![]() ![]() Group: Members Posts: 670 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California ![]() ![]() |
![]() The engine, transaxle, and all the assemblies under the car are off (e.g. brakes, suspension, fuel lines). I’m hoping to get it back on four wheels this trip and am attempting to identify order of operations, so I don’t waste my limited time with the car redoing things. Will this order of assembly cause me any problems? Have I overlooked anything? All related components have been rebuilt or replaced. Sorry for the long post... ON LIFT * Steering rack - Installed * Brake master cylinder - Installed 1. Brakes a. Hard brake lines OFF LIFT ON JACK STANDS DUE TO RAMP CLEARANCE 2. Suspension - Front a. Cross member b. Torsion bars c. Control arms d. Ball joints e. Struts f. Tie rod ends g. Hub with bearings installed 3. Suspension - Rear a. Shocks b. Trailing arms - Bearings and Hubs installed c. Axles with CV joints 1. Brakes - Continued b. Soft brake lines c. Brake shields d. Rotors e. Calipers f. Pads g. Wheels OFF STANDS ON LIFT 4. Fuel a. Fuel lines b. Fuel pump c. Gas tank 5. Engine a. Engine mounts b. Suspension mounts c. Exhaust on engine d. Engine mated with transaxle e. Engine / transaxle install in car Thank you. |
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,650 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
I’d install engine before rear trailing arms, sure is nice to have all that room. Careful of the weight balance on the lift as you add weight to the rear, front can get light.
JamesM |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,100 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
I’d install engine before rear trailing arms (IMG:style_emoticons/default/agree.gif) That Especially if you are doing a high level restoration where you don't want to scratch up your engine tin. its not the CV axels that are the problem, its the rear control arm pivot nuts. |
DennisV |
After my best effort to prep and avoid remove and replace, I ended up making a rookie mistake. I installed the steering rack before attaching the fork joint and track rod. There isn't enough clearance to get the bolt through the fork joint / eye bolt after the steering rack is mounted. (IMG:style_emoticons/default/headbang.gif)
I assume I haven't read about this anywhere because most people are installing the turbo tie rod end that don't require the bolt. Maybe this note will safe someone else a headache down the road. |
Lo-Fi Version | Time is now: 7th July 2025 - 02:02 PM |
