> 67 911 charging/battery issues, It's why I can't make WCR!
FlacaProductions
post Jun 22 2025, 06:27 PM
@bdstone914 - you asked - here it is! (posted here because you guys are smart and hands on - the 911 board is less hands on...)
1967 911 coupe. Just completed a “wake-up” after sitting rarely used by the previous owner for a few years. Main issue was gummed up carbs, but all suspension/running/stopping gear restored/replaced generally to OEM/stock specs.
I picked it up April 17 after 2 months of restoration. Ran like clockwork until June 9.
My overall suspicion with this issue - a bad voltage regulator (although I never get an alternator warning light unless it’s at initial start and until the revs have been up for just a bit and then the light goes out as expected/normal) - and/or heat induced high resistance around starter wiring.
Except as noted, headlights/dash lights/accessories all work as expected - even when battery acts dead and won’t turn over the starter.
first incident - Monday, June 9
cold starts fine and drive to anaheim. about an hour - freeway all the way. lights, radio on all the way. no performance issues or dash indicators.
Parked - went to move 5 mins later and it wouldn’t start. slow turnover until battery finally died. portable jump start brought it back and I moved about 50 yards. I thought I’d just jump it again if it failed to start but that wasn’t possible. jump box finally depleted. Clay from Scott’s Independent was about 15 minutes away and brought me a charged battery. Put it in and car fired right away.
to the shop - tested charging system and all seemed well - including swapping of a couple of voltage regulators with no real difference noted to voltage/charge numbers at the battery.
Wrote it off to a battery failure, installed new Interstate and away I went.
After that day, I’ve done multiple small, 10-30 minute “exercise” runs around my area without incident. Including multiple drive/stop/park/start/drive scenarios. Groceries, fuel, errands, etc.
friday June 20 - angeles crest - again - no issues
started fine - ran continuously/aggressively on the freeway and up the hill for 60+ minutes/60 miles. stopped at the top for an hour. Started fine for return. stopped for gas near home - started back up fine.
lights on all the way.
charging phone (rennline iPhone charging mount)
radio on
no issues
saturday June 21 - latest incident
started fine
ran slow up PCH (30 mph for 60 mins) to canyon run at highway speeds, back down 101 to malibu canyon again at highway speeds, stopped for dinner.
on that last leg, I noticed that the the phone didn’t charge and I didn’t have the horn - but did have the horn at beginning of ride. (I always honk coming out of our condo garage as it's somewhat blind to pedestrians)
After dinner, it seemed to crank JUST a bit slower after dinner but started easily. phone charged and had horn.
ran 30mph down PCH (30 mph) just fine for 45 minutes. Lights on. Radio on.
On Sunset, started to stumble (40mph) - especially when going past half throttle. big backfires. finally stumbled and quit.
Side of the road. wouldn’t turn over. lights etc all work. wouldn’t jump start. Left it - came back after an hour - turned over slowly - wouldn’t start. started with jump box. drove home without incident. wouldn’t crank when i got it home.
Sunday june 22 - wouldn’t crank - acts like dead battery. starts with either jump box or after trickle charger applied for a while.
Any input is appreciated - sorry for the long post - just trying to do a stream of consciousness of the details....
FlacaProductions
post Jun 24 2025, 12:14 PM
I know the bulb is good - checked it the other day - but will check the bulb carrier voltage in the next couple of days when able.
thank you!
doesn't seem like a fuel issue, George but I see what you're thinking there.
FlacaProductions   67 911 charging/battery issues   Jun 22 2025, 06:27 PM
jim_hoyland   FI or carbs ?   Jun 22 2025, 07:48 PM
FlacaProductions   Carbs   Jun 22 2025, 07:51 PM
Chris914n6   Sounds like turning the headlights on is the probl...   Jun 22 2025, 08:29 PM
FlacaProductions   It's funny - I turn the lights on every time -...   Jun 22 2025, 09:01 PM
Superhawk996   I’m not a 911 guy “Side of the road. wouldn...   Jun 22 2025, 10:30 PM
FlacaProductions   The more I think/read about things, the more I agr...   Jun 23 2025, 08:11 AM
infraredcalvin   Don’t count on the shops trouble shooting on int...   Jun 23 2025, 08:34 AM
Spoke   In your description of the issues, I didn't se...   Jun 23 2025, 08:48 AM
FlacaProductions   I don't have a voltmeter on the 911 but the ci...   Jun 23 2025, 09:31 AM
rhodyguy   On the 21st both the horn and phone charging? circ...   Jun 23 2025, 10:16 AM
FlacaProductions   Hi @rhodyguy - it's interesting those circui...   Jun 23 2025, 06:18 PM
Superhawk996   One other thing comes to mind. Keep in mind I...   Jun 23 2025, 07:23 PM
FlacaProductions   I'll catch anything you're throwing! A...   Jun 23 2025, 08:01 PM
Superhawk996   I was at an event today with Peter Egan and the ...   Jun 23 2025, 08:20 PM
Artfrombama   Charging indicator light should burn with the key ...   Jun 23 2025, 09:01 PM
FlacaProductions   My charging indicator does NOT burn with the key o...   Jun 24 2025, 07:59 AM
FlacaProductions   Yeah. Confirmed. No light with key on, not running...   Jun 24 2025, 09:39 AM
Artfrombama   Yeah. Confirmed. No light with key on, not runnin...   Jun 24 2025, 10:35 AM
Spoke   Yeah. Confirmed. No light with key on, not runnin...   Jun 24 2025, 11:41 AM
slivel   The battery cables - positive and negative can loo...   Jun 24 2025, 09:50 AM
dr914@autoatlanta.com   If the alternator is charging at 13.6-13.9 religio...   Jun 24 2025, 11:32 AM
FlacaProductions   I know the bulb is good - checked it the other day...   Jun 24 2025, 12:14 PM
FlacaProductions   Dropped it at the shop on Friday - missing WCR...   Jun 28 2025, 07:23 PM
FlacaProductions   Wrapping this up - the great guys at Scott's I...   Jun 30 2025, 04:18 PM
porschetub   Wrapping this up - the great guys at Scott's ...   Jul 1 2025, 06:35 PM
brant   Just throwing this out May not be related to probl...   Jun 30 2025, 04:41 PM
FlacaProductions   That's interesting and good to know. I am not...   Jun 30 2025, 04:50 PM
Stratfink   Glad you got it sorted Brian - we missed you at WC...   Jul 1 2025, 11:59 PM
- Lo-Fi Version Time is now: 30th April 2026 - 07:38 AM
