> Rear Caliper Install Rotor Clearance Issue, 914-6
DennisV
post Jun 24 2025, 08:11 PM
I have newly restored calipers from PMB. They look great. Front went on no problem. The rear have been a real bear. I've tried both sides and I can't get reasonable clearance between the caliper (no pads) and rotor. I wonder if I have the alignment of parts wrong. (IMG:style_emoticons/default/confused24.gif)
My understanding, working from outside in, is:
Trailing arm mount <- cover plate bracket <- caliper <- bolt
Meaning the cover plate bracket is sandwiched between the caliper and trailing arm. Do I have that right? I tried the reverse as well and it still didn't line up well. (IMG:style_emoticons/default/blink.gif)
Not sure what I'm doing wrong... Damn you Ian Karr and your videos that make this look so easy. (IMG:style_emoticons/default/biggrin.gif)
P.S. As you can see in the photo, the rotors are not vented so that should not be adding to any clearance issues.
Superhawk996
post Jun 25 2025, 07:02 AM
Warning. - do not roll the car around without those stubs installed. It will damage the wheel bearings. Suspect that hasn’t happend because the car is still on the hoist but don’t do that if the temptation arises.
- Lo-Fi Version Time is now: 7th July 2025 - 04:59 AM
