Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,983 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
1.7 w/ original D-jet.
I have the idle screw on the TB cranked all the way down/closed (which doesn't seem right tbh) and the car's idleing around 900rpm - which is within the recommended 850+/- , and the idle does not really "surge" too much but is not necessarily rock steady either. I'm also getting a steady 16.5 A/F on my gauge during idle and warm driving. So too lean. BTW, the CHT gauge has never gotten over 300 so it's not trying to over heat. I'll be spraying the vacuum connections to see if I can find leaks - but other than that, what would be the most obvious culprit(s)? My theory is that the idle screw needing to be closed (for a reasonable idle) is just combating say, a bad AAR or something. Sound logical? What tests can I do to the AAR or other items to look at first? |
Ishley |
Member ![]() ![]() Group: Members Posts: 219 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest ![]() ![]() |
My ‘72 has the idle mixture knob on the ECU.
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,979 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
My ‘72 has the idle mixture knob on the ECU. Well, you could richen it with that. I suspect as the engine ages it probably has different requirements from when it left the factory. Have you tried some PEA fuel system cleaner? Like the 10$ gumout stuff? Maybe your injectors are getting gummy. A lean mix is gonna play havoc with idle, could be as simple as a bad tank of gas.... |
Lo-Fi Version | Time is now: 1st July 2025 - 11:09 AM |
