Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,983 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
1.7 w/ original D-jet.
I have the idle screw on the TB cranked all the way down/closed (which doesn't seem right tbh) and the car's idleing around 900rpm - which is within the recommended 850+/- , and the idle does not really "surge" too much but is not necessarily rock steady either. I'm also getting a steady 16.5 A/F on my gauge during idle and warm driving. So too lean. BTW, the CHT gauge has never gotten over 300 so it's not trying to over heat. I'll be spraying the vacuum connections to see if I can find leaks - but other than that, what would be the most obvious culprit(s)? My theory is that the idle screw needing to be closed (for a reasonable idle) is just combating say, a bad AAR or something. Sound logical? What tests can I do to the AAR or other items to look at first? |
Literati914 |
Did restoring it include a motor rebuild or a new mps? The car was in need of restoration but the engine was out of the car and supposedly freshly rebuilt .. but no receipts. It was certainly clean and some items obviously new. I believe the MPS is original .. apparently untouched also. It’s the correct model for my ECU, which is correct for the ‘72 as well. |
Lo-Fi Version | Time is now: 1st July 2025 - 02:57 PM |
