> D-jet idle and lean issues.
Literati914
post Jun 27 2025, 09:41 AM
1.7 w/ original D-jet.
I have the idle screw on the TB cranked all the way down/closed (which doesn't seem right tbh) and the car's idleing around 900rpm - which is within the recommended 850+/- , and the idle does not really "surge" too much but is not necessarily rock steady either. I'm also getting a steady 16.5 A/F on my gauge during idle and warm driving. So too lean. BTW, the CHT gauge has never gotten over 300 so it's not trying to over heat.
I'll be spraying the vacuum connections to see if I can find leaks - but other than that, what would be the most obvious culprit(s)?
My theory is that the idle screw needing to be closed (for a reasonable idle) is just combating say, a bad AAR or something. Sound logical? What tests can I do to the AAR or other items to look at first?
Literati914
post Jun 27 2025, 08:18 PM
QUOTE(JeffBowlsby @ Jun 27 2025, 07:40 PM) *
A reminder that the ECU idle mixture knob is only active when the TPS is correctly calibrated. Two of the circuits in the TPS are a switch that tells the ECU to control mixture at idle, and you should see a difference in the lean/rich condition at idle under that condition. Off idle, the TPS turns off the ECU-controlled idle mixture function, and directs the other sensors combined (MPS, TS1, TS2) to control mixture as determined by the monitored engine conditions.
If there is no reaction from the ECU knob at idle, then the TPS is likely not calibrated correctly.
Hey Jeff - it’s interesting that you brought up the subjects of the knob “only changing idle mixture”… why? Because I just spent some time with my ecu and got the knob to the center spot (actually maybe 1 click rich). To do this I had to move it CCW from where I had it on my last run. It did not change the 16.5 at the gauge while idleing (or driving). But this time while test driving the car it tended to want to back-fire and pop!
Two things with that: the knob shouldn’t effect driving mix, and I thought back-firing and popping were indicative of being over rich (I moved ccw leaner) ?
I messed with attempting to configure my TPS before installing my replacement TB last week. Here’s a pic of how mine lined up:
Literati914   D-jet idle and lean issues.   Jun 27 2025, 09:41 AM
ctc911ctc   I vote: Vacuum leak throttle body and Plenum Go...   Jun 27 2025, 12:58 PM
rjames   You may have a vacuum leak, but it sounds like you...   Jun 27 2025, 01:56 PM
emerygt350   Mixture is unaffected by leaks. Idle rpm is. I a...   Jun 27 2025, 02:29 PM
Ishley   My ‘72 has the idle mixture knob on the ECU.   Jun 27 2025, 04:09 PM
emerygt350   My ‘72 has the idle mixture knob on the ECU. ...   Jun 27 2025, 04:14 PM
Literati914   My ‘72 has the idle mixture knob on the ECU. ...   Jun 27 2025, 05:38 PM
Literati914   You guys asked if this condition just started - we...   Jun 27 2025, 05:54 PM
rjames   You guys asked if this condition just started - w...   Jun 27 2025, 06:17 PM
Ishley   My 72 ECU knob does nothing. I have an Air fuel ga...   Jun 27 2025, 05:58 PM
JeffBowlsby   A reminder that the ECU idle mixture knob is only ...   Jun 27 2025, 06:40 PM
Literati914   Did restoring it include a motor rebuild or a new...   Jun 27 2025, 08:02 PM
emerygt350   What Jeff said. That is a good sign that your TPS ...   Jun 27 2025, 08:06 PM
Literati914   A reminder that the ECU idle mixture knob is only...   Jun 27 2025, 08:18 PM
Literati914   A reminder that the ECU idle mixture knob is only...   Jun 27 2025, 08:20 PM
brant   16.5 at all conditions seems wrong Idle mixture d...   Jun 27 2025, 08:21 PM
emerygt350   Did you set the TPS according to the instructions?...   Jun 28 2025, 05:26 AM
JeffBowlsby   That TPS board is worn out, should be replaced.   Jun 28 2025, 08:13 AM
Ishley   You might want to try a new O2 sensor. I’ve have...   Jun 28 2025, 10:45 AM
emerygt350   I have been using disposable Amazon o2 sensors. 29...   Jun 28 2025, 02:07 PM
Literati914   Yes the MPS still has original rivets and opeque p...   Jun 28 2025, 08:00 PM
JeffBowlsby   TPS calibration method 1.7L if you don’t have it...   Jun 28 2025, 08:58 PM
emerygt350   These cars will do fine without the TPS so it can ...   Jun 29 2025, 04:02 AM
Literati914   Yea I think I actually have two separate issues go...   Jun 29 2025, 11:49 AM
- Lo-Fi Version Time is now: 1st July 2025 - 10:21 AM
