fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
Decided to change the trans oil, I can't remember the last time it was done.
So I found a thread from a year ago about the suggested oil to use (non-synthetic, 80-90 GL-5). Going to pick up 3 quarts shortly. Drained the oil after I had it out for a half-hour or so run, looks like it emptied pretty well. Any need to to 'flush' it, or otherwise clean things out? Old oil was pretty black, but no sludge I could see. |
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 671 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
Decided to change the trans oil, I can't remember the last time it was done. So I found a thread from a year ago about the suggested oil to use (non-synthetic, 80-90 GL-5). Going to pick up 3 quarts shortly. Drained the oil after I had it out for a half-hour or so run, looks like it emptied pretty well. Any need to to 'flush' it, or otherwise clean things out? Old oil was pretty black, but no sludge I could see. There are no passages or pumps in there. Unless you are really worried about sludge buildup, just add the new gear oil. And, if you are worried, just change it sooner, next time. |
fixer34 |
Decided to change the trans oil, I can't remember the last time it was done. So I found a thread from a year ago about the suggested oil to use (non-synthetic, 80-90 GL-5). Going to pick up 3 quarts shortly. Drained the oil after I had it out for a half-hour or so run, looks like it emptied pretty well. Any need to to 'flush' it, or otherwise clean things out? Old oil was pretty black, but no sludge I could see. There are no passages or pumps in there. Unless you are really worried about sludge buildup, just add the new gear oil. And, if you are worried, just change it sooner, next time. nothing concerning when I dumped the oil from the drain pan to a bottle, stuck my finger inside and no sludge buildup, so I'll refill and go. Thanks. |
Lo-Fi Version | Time is now: 1st July 2025 - 06:41 PM |
