Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,983 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
1.7 w/ original D-jet.
I have the idle screw on the TB cranked all the way down/closed (which doesn't seem right tbh) and the car's idleing around 900rpm - which is within the recommended 850+/- , and the idle does not really "surge" too much but is not necessarily rock steady either. I'm also getting a steady 16.5 A/F on my gauge during idle and warm driving. So too lean. BTW, the CHT gauge has never gotten over 300 so it's not trying to over heat. I'll be spraying the vacuum connections to see if I can find leaks - but other than that, what would be the most obvious culprit(s)? My theory is that the idle screw needing to be closed (for a reasonable idle) is just combating say, a bad AAR or something. Sound logical? What tests can I do to the AAR or other items to look at first? |
Literati914 |
Yes the MPS still has original rivets and opeque plug.
I originally set the TPS via a picture (from a post about setting the TPS), used the picture because the ohms were all over the place. Today I decided to try again and concentrate on getting the Ohms method correct - maybe my craftsman digital multimeter is acting up or something, but again the Ohms search at the TPS was not helpful. I set it back basically with a small tweek. This time my idle is at 1100rpm (remember my idle screw is max closed). So i guess a tps board replacement is next … i didn’t worry too much about it because the acceleration is good and smooth. BTW, I am getting back-firing at deceleration, like pushing it hard in 3rd and going into neutral while braking (for example). 1 click past center on ECU though I know that should only matter at idle. |
Lo-Fi Version | Time is now: 1st July 2025 - 07:50 AM |
