> Trailing Arm Install Questions, Camber Shim and Washer
DennisV
post Jun 20 2025, 07:06 PM
Is this the correct placement for the camber alignment shim on the rear trailing arm? it seems weird to me that it sticks off at the corner like that, but I can't find any other orientation that allow 3 bolt holes to line up.
Does the washer go on the trailing arm side of the body tab, as opposed to the nut side?
Thank you.
Montreal914
post Jun 29 2025, 12:19 PM
Humm... Interesting (IMG:style_emoticons/default/idea.gif)
Am I understanding correctly what is being said here is that the washer should be placed between the rubber bushing flange (shaft end) and the suspension ear?
I have never seen this washer in between the arm's rubber bushing and the suspension ear on my car. I always thought the pivot shaft serrations were supposed to grab on the surface of the suspension ear to prevent the shaft from rotating (although that is a lot to ask).
Picture below shows the serration marks from the shaft to the suspension ear and rubbing of the rubber bushing against the metal, which seens to be what it would be designed for.
@bdstone914 , @mepstein , please share your recollection of that assembled area, thanks!
Superhawk996
post Jun 29 2025, 12:38 PM
QUOTE(Montreal914 @ Jun 29 2025, 02:19 PM) *
You are correct
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: mxkinn01
- Lo-Fi Version Time is now: 1st July 2025 - 10:53 AM
