> 123Ignition Static Timing, Engine will not start
SteveNMaine
post Jul 1 2025, 10:08 AM
I just setup my carbureted 2056 with 123Ignition distributor and cannot get it started.
Basics: Compression is good, new dual carbs and there is spark.
I have read several methods of setting static timing,
Method 1: 123 manual says set timing marks at 0 TDC and turn distributor till light turns green, I did that, no Joy.
Method 2: Set timing marks at 7.5 BTDC and turn distributor till light turns green, I did that, it sounded more like it wanted to start but no joy.
Should I continue to advance the timing?
IronHillRestorations
post Jul 3 2025, 02:53 PM
I. I. R. C.
Make sure there’s a center contact in the distributor cap. I’ve seen that problem a couple times.
SteveNMaine   123Ignition Static Timing   Jul 1 2025, 10:08 AM
jim_hoyland   Call Ed at 1-2-3 (440) 668-8164 He’s the guru   Jul 1 2025, 10:53 AM
wbgoggans   Call Ed at 1-2-3 (440) 668-8164 He’s the guru ...   Jul 1 2025, 03:20 PM
FlacaProductions   Yup. Install and rotate counter-clockwise juuuuus...   Jul 1 2025, 04:05 PM
Robarabian   What Flaca said... you don't just turn it... a...   Jul 1 2025, 05:56 PM
dtmehall   not to be a dinosaur, but this is a very similar p...   Jul 1 2025, 08:56 PM
SteveNMaine   I have the 123/TUNE+4-R-V-POR What should I be pro...   Jul 2 2025, 04:37 AM
FlacaProductions   Here's a note I have saved from Ian concerning...   Jul 2 2025, 08:09 AM
SteveNMaine   Here's a note I have saved from Ian concernin...   Jul 3 2025, 01:57 PM
SteveNMaine   [quote name='FlacaProductions' post='3212878' dat...   Jul 3 2025, 06:18 PM
Superhawk996   I still have not been able to get my 2056 to star...   Jul 3 2025, 09:17 AM
SteveNMaine   I still have not been able to get my 2056 to sta...   Jul 4 2025, 09:50 AM
IronHillRestorations   If it ran well before you pulled the distributor, ...   Jul 3 2025, 09:38 AM
IronHillRestorations   Make sure there’s a center contact in the distri...   Jul 3 2025, 02:53 PM
emerygt350   Have you tried starting fluid? Timing is just tim...   Jul 3 2025, 06:34 PM
Stratfink   Hang in there Steve. Several of us struggled to ge...   Jul 3 2025, 11:12 PM
Superhawk996   Cool - glad you don’t want to give up just yet. ...   Jul 4 2025, 10:26 AM
SteveNMaine   Cool - glad you don’t want to give up just yet....   Jul 4 2025, 06:58 PM
Superhawk996   The dizzy drive gear installation and proper posit...   Jul 4 2025, 10:30 AM
SteveNMaine   The dizzy drive gear installation and proper posi...   Jul 5 2025, 06:36 AM
cassmcentee   Here is a pic of how mine is installed, I believe ...   Jul 5 2025, 06:47 AM
Superhawk996   Looking at the installation page it says the tim...   Jul 5 2025, 06:59 AM
Superhawk996   Sort of assumed you knew you’re getting fuel due...   Jul 4 2025, 07:06 PM
SteveNMaine   So, I removed the 123 dizzy and checked the drive ...   Jul 5 2025, 08:51 AM
emerygt350   You need to be more descriptive than 'not star...   Jul 5 2025, 10:37 AM
Superhawk996   Good job putting the dizzy drive to correct positi...   Jul 5 2025, 10:59 AM
Superhawk996   Also have questions about the carbs. 1) Are thes...   Jul 5 2025, 11:07 AM
iankarr   Hang in there! As others have said, it will be...   Jul 5 2025, 11:56 AM
SteveNMaine   The carbs are brand new; linkage is hooked up to b...   Jul 5 2025, 02:01 PM
Superhawk996   The carbs are brand new; linkage is hooked up to ...   Jul 5 2025, 03:45 PM
OrangeBones   It might be the fueling but if you can shoot video...   Jul 5 2025, 06:02 PM
emerygt350   Engines start easier a little retarded on the timi...   Jul 5 2025, 07:24 PM
IronHillRestorations   I’m still not convinced that the timing is set a...   Jul 6 2025, 06:43 AM
fixer34   I’m still not convinced that the timing is set ...   Jul 6 2025, 11:55 AM
IronHillRestorations   I’m still not convinced that the timing is set...   Jul 6 2025, 07:01 PM
iankarr   Is there a new cam in the engine? If so, I'd m...   Jul 6 2025, 03:21 PM
SteveNMaine   Is there a new cam in the engine? If so, I'd ...   Jul 7 2025, 04:34 AM
iankarr   Is there a new cam in the engine? If so, I'd...   Jul 8 2025, 11:27 PM
Rob-O   I’m still not convinced that the timing is set ...   Jul 6 2025, 06:07 PM
IronHillRestorations   Take the driver side valve cover off and confirm b...   Jul 6 2025, 08:23 PM
IronHillRestorations   duplicate   Jul 6 2025, 08:23 PM
emerygt350   If the cam is off a tooth or three it will.   Jul 7 2025, 04:48 AM
SteveNMaine   If the cam is off a tooth or three it will. Let...   Jul 7 2025, 06:13 AM
emerygt350   If the cam is off a tooth or three it will. Let...   Jul 7 2025, 06:32 AM
SteveNMaine   Last year I purchased a 1975 2.0 that had been rem...   Jul 7 2025, 07:54 AM
emerygt350   I would still verify, just to be absolutely certai...   Jul 7 2025, 08:10 AM
SteveNMaine   I would still verify, just to be absolutely certa...   Jul 7 2025, 08:54 AM
Superhawk996   With all due respect - the advance curve has nothi...   Jul 7 2025, 09:18 AM
SteveNMaine   At TDC the valves 0n #1 are closed, timing marks o...   Jul 7 2025, 12:10 PM
emerygt350   All that's left is spark and compression.... ...   Jul 7 2025, 02:47 PM
Front yard mechanic   I used the coil from 123 and have the model w/ no ...   Jul 7 2025, 03:21 PM
SteveNMaine   So, I spoke with Ed at 123 and he suggested cranki...   Jul 7 2025, 06:37 PM
IronHillRestorations   Good to hear you’ve got it to start :headbanger...   Jul 7 2025, 08:11 PM
SteveNMaine   So, the next puzzle is this; when the 123 is setup...   Jul 9 2025, 05:34 AM
emerygt350   So, the next puzzle is this; when the 123 is setu...   Jul 9 2025, 06:59 AM
VaccaRabite   So, the next puzzle is this; when the 123 is setu...   Jul 9 2025, 04:15 PM
fixer34   I'm not familiar with the 123 unit, the 50yr o...   Jul 9 2025, 07:09 AM
nditiz1   It is recommended to create a 0 degree file. Make...   Jul 9 2025, 07:11 AM
emerygt350   I do this all the time. Not the 180 out but putti...   Jul 9 2025, 06:23 PM
SteveNMaine   So, what I discovered: The plate under the rotor ...   Jul 10 2025, 06:30 AM
emerygt350   Well, that makes sense. I seem to remember that wh...   Jul 10 2025, 09:15 AM
- Lo-Fi Version Time is now: 30th May 2026 - 03:05 AM
