| SteveNMaine |
Jul 1 2025, 10:08 AM
Member ![]() ![]() Group: Members Posts: 94 Joined: 12-August 24 From: Maine Member No.: 28,288 Region Association: None |
I just setup my carbureted 2056 with 123Ignition distributor and cannot get it started.
Basics: Compression is good, new dual carbs and there is spark. I have read several methods of setting static timing, Method 1: 123 manual says set timing marks at 0 TDC and turn distributor till light turns green, I did that, no Joy. Method 2: Set timing marks at 7.5 BTDC and turn distributor till light turns green, I did that, it sounded more like it wanted to start but no joy. Should I continue to advance the timing? |
| Superhawk996 |
Jul 4 2025, 07:06 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,846 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Sort of assumed you knew you’re getting fuel due to the carbs but am still curious what it’s doing as you crank.
Are you getting any firing of the cylinders and it just won’t catch? Is it backfiring? Slow cranking without enough oomph to really spin it over ? What do the plugs look like - are the wet and flooded & fouled or brand new white insulators with no evidence of combustion. You say you have spark - is it hot blue / white or sort of weak and yellow? If you can post a video to YouTube and link that would be extremely helpful Likewise - you should verify the dizzy drive is installed properly. Again - pics are helpful to verify. |
SteveNMaine 123Ignition Static Timing Jul 1 2025, 10:08 AM
jim_hoyland Call Ed at 1-2-3
(440) 668-8164
He’s the guru Jul 1 2025, 10:53 AM
wbgoggans
Call Ed at 1-2-3
(440) 668-8164
He’s the guru
... Jul 1 2025, 03:20 PM
FlacaProductions Yup. Install and rotate counter-clockwise juuuuus... Jul 1 2025, 04:05 PM
Robarabian What Flaca said... you don't just turn it... a... Jul 1 2025, 05:56 PM
dtmehall not to be a dinosaur, but this is a very similar p... Jul 1 2025, 08:56 PM
SteveNMaine I have the 123/TUNE+4-R-V-POR What should I be pro... Jul 2 2025, 04:37 AM
FlacaProductions Here's a note I have saved from Ian concerning... Jul 2 2025, 08:09 AM
SteveNMaine
Here's a note I have saved from Ian concernin... Jul 3 2025, 01:57 PM
SteveNMaine
[quote name='FlacaProductions' post='3212878' dat... Jul 3 2025, 06:18 PM
Superhawk996
I still have not been able to get my 2056 to star... Jul 3 2025, 09:17 AM
SteveNMaine
I still have not been able to get my 2056 to sta... Jul 4 2025, 09:50 AM
IronHillRestorations If it ran well before you pulled the distributor, ... Jul 3 2025, 09:38 AM
IronHillRestorations Make sure there’s a center contact in the distri... Jul 3 2025, 02:53 PM
emerygt350 Have you tried starting fluid?
Timing is just tim... Jul 3 2025, 06:34 PM
Stratfink Hang in there Steve. Several of us struggled to ge... Jul 3 2025, 11:12 PM
Superhawk996 Cool - glad you don’t want to give up just yet. ... Jul 4 2025, 10:26 AM
SteveNMaine
Cool - glad you don’t want to give up just yet.... Jul 4 2025, 06:58 PM
Superhawk996 The dizzy drive gear installation and proper posit... Jul 4 2025, 10:30 AM
SteveNMaine
The dizzy drive gear installation and proper posi... Jul 5 2025, 06:36 AM
cassmcentee Here is a pic of how mine is installed, I believe ... Jul 5 2025, 06:47 AM
Superhawk996
Looking at the installation page it says the tim... Jul 5 2025, 06:59 AM
SteveNMaine So, I removed the 123 dizzy and checked the drive ... Jul 5 2025, 08:51 AM
emerygt350 You need to be more descriptive than 'not star... Jul 5 2025, 10:37 AM
Superhawk996 Good job putting the dizzy drive to correct positi... Jul 5 2025, 10:59 AM
Superhawk996 Also have questions about the carbs.
1) Are thes... Jul 5 2025, 11:07 AM
iankarr Hang in there! As others have said, it will be... Jul 5 2025, 11:56 AM
SteveNMaine The carbs are brand new; linkage is hooked up to b... Jul 5 2025, 02:01 PM
Superhawk996
The carbs are brand new; linkage is hooked up to ... Jul 5 2025, 03:45 PM
OrangeBones It might be the fueling but if you can shoot video... Jul 5 2025, 06:02 PM
emerygt350 Engines start easier a little retarded on the timi... Jul 5 2025, 07:24 PM
IronHillRestorations I’m still not convinced that the timing is set a... Jul 6 2025, 06:43 AM
fixer34
I’m still not convinced that the timing is set ... Jul 6 2025, 11:55 AM
I’m still not convinced that the timing is set... Jul 6 2025, 07:01 PM
iankarr Is there a new cam in the engine? If so, I'd m... Jul 6 2025, 03:21 PM
SteveNMaine
Is there a new cam in the engine? If so, I'd ... Jul 7 2025, 04:34 AM
iankarr
Is there a new cam in the engine? If so, I'd... Jul 8 2025, 11:27 PM
Rob-O
I’m still not convinced that the timing is set ... Jul 6 2025, 06:07 PM
IronHillRestorations Take the driver side valve cover off and confirm b... Jul 6 2025, 08:23 PM
IronHillRestorations duplicate Jul 6 2025, 08:23 PM
emerygt350 If the cam is off a tooth or three it will. Jul 7 2025, 04:48 AM
SteveNMaine
Let... Jul 7 2025, 06:13 AM
emerygt350
Let... Jul 7 2025, 06:32 AM
SteveNMaine Last year I purchased a 1975 2.0 that had been rem... Jul 7 2025, 07:54 AM
emerygt350 I would still verify, just to be absolutely certai... Jul 7 2025, 08:10 AM
SteveNMaine
I would still verify, just to be absolutely certa... Jul 7 2025, 08:54 AM
Superhawk996 With all due respect - the advance curve has nothi... Jul 7 2025, 09:18 AM
SteveNMaine At TDC the valves 0n #1 are closed, timing marks o... Jul 7 2025, 12:10 PM
emerygt350 All that's left is spark and compression.... ... Jul 7 2025, 02:47 PM
Front yard mechanic I used the coil from 123 and have the model w/ no ... Jul 7 2025, 03:21 PM
SteveNMaine So, I spoke with Ed at 123 and he suggested cranki... Jul 7 2025, 06:37 PM
IronHillRestorations Good to hear you’ve got it to start :headbanger... Jul 7 2025, 08:11 PM
SteveNMaine So, the next puzzle is this; when the 123 is setup... Jul 9 2025, 05:34 AM
emerygt350
So, the next puzzle is this; when the 123 is setu... Jul 9 2025, 06:59 AM
VaccaRabite
So, the next puzzle is this; when the 123 is setu... Jul 9 2025, 04:15 PM
fixer34 I'm not familiar with the 123 unit, the 50yr o... Jul 9 2025, 07:09 AM
nditiz1 It is recommended to create a 0 degree file. Make... Jul 9 2025, 07:11 AM
emerygt350 I do this all the time. Not the 180 out but putti... Jul 9 2025, 06:23 PM
SteveNMaine So, what I discovered:
The plate under the rotor ... Jul 10 2025, 06:30 AM
emerygt350 Well, that makes sense. I seem to remember that wh... Jul 10 2025, 09:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th May 2026 - 03:06 AM |
