| Mr.Vman |
May 2 2025, 05:49 PM
Newbie ![]() Group: Members Posts: 27 Joined: 1-October 24 From: Sierra Vista, AZ. Member No.: 28,388 Region Association: Southwest Region |
The 1976 914 build continues, Question on the master cylinder lines from brake fluid reservoir. Do the hard lines from the reservoir just push into the rubber grommet on top of the master cylinder? I tried pushing the lines in, would not stay and leaked. Also, no click that I have read about. Are there washers that are installed before the flared end of the reservoir lines? Perhaps remove the rubber grommets from the master cylinder, install reservoir lines into grommets and then install assembly into master cylinder? What is the order the lines are pushed into the master cylinder? Where do the washers go? How deep do the hard lines fit into the grommets? Through the rubber grommet and into the master cylinder? Thanks in advance, stalled on this one. Steve
| VaccaRabite |
Jul 5 2025, 10:01 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,807 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
So I tried something new this week. I always do this task on the bench, not under the car. Popped the grommets out and put them on the lines. Then used a plastic trim spudger to work the grommets back into the master.
Usually I try to work the lines into the grommets while the grommets are in the master. Zach |
Mr.Vman Brake master cylinder grommets May 2 2025, 05:49 PM
mepstein The small metal spacers go into the mc, under the ... May 2 2025, 05:59 PM
fiacra
The small metal spacers go into the mc, under the... May 2 2025, 08:32 PM
Mr.Vman Thanks for the replies. Order of install; Metal ... May 2 2025, 11:19 PM
fiacra
Thanks for the replies. Order of install; Metal... May 3 2025, 11:31 AM
DennisV
Don't forget the seals/rubber sleeves (part #... Jul 4 2025, 06:31 AM
fiacra
Don't forget the seals/rubber sleeves (part ... Jul 4 2025, 08:54 AM
DennisV
You are correct. I had the wrong part number in ... Jul 5 2025, 04:25 PM
fiacra
[quote name='fiacra' post='3213273' date='Jul 4 2... Jul 5 2025, 06:56 PM
mepstein Some mc’s come with the metal washers installed,... May 3 2025, 02:39 AM
Mr.Vman Removed Master cylinder grommets, no washers in th... May 3 2025, 11:52 AM
Removed Master cylinder grommets, no washers in t... May 3 2025, 01:22 PM
Literati914
Removed Master cylinder grommets, no washers in t... May 3 2025, 12:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2025 - 07:10 AM |
