Gatornapper |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,283 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States ![]() ![]() |
Once again need the help of the great 914 Brain Trust here........
My Parking Brake Light stays on all the time. The switch is fairly new and it is functioning properly. Disconnecting the brown (ground) wire to the switch, it has no continuity or resistance to ground. So it is not "grounded out" somewhere. I see in my great 914 electrical schematic of the ground circuit for the switch and light that there are two diodes in the circuit. I am guessing that one of them failed. Can anyone tell me where these two diodes are located? Or where else the problem might be? As always, TIA, GN |
Gatornapper |
Ah, yes.
Thank you SH for the schematic. NO diodes at light in left gauge - none in sight anywhere. See none in schematic above either. My 914 is '76. But I will check the Brake Fluid. I just bled the brakes a week ago with 15psi on fluid reservoir system. So reservoir is full. GN |
Lo-Fi Version | Time is now: 3rd September 2025 - 06:14 PM |
