| SteveNMaine |
Jul 1 2025, 10:08 AM
Member ![]() ![]() Group: Members Posts: 94 Joined: 12-August 24 From: Maine Member No.: 28,288 Region Association: None |
I just setup my carbureted 2056 with 123Ignition distributor and cannot get it started.
Basics: Compression is good, new dual carbs and there is spark. I have read several methods of setting static timing, Method 1: 123 manual says set timing marks at 0 TDC and turn distributor till light turns green, I did that, no Joy. Method 2: Set timing marks at 7.5 BTDC and turn distributor till light turns green, I did that, it sounded more like it wanted to start but no joy. Should I continue to advance the timing? |
| emerygt350 |
Jul 10 2025, 09:15 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,592 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Well, that makes sense. I seem to remember that when I installed mine. I ended up calling tangerine racing (where I bought it) and Chris walked me through it
SteveNMaine 123Ignition Static Timing Jul 1 2025, 10:08 AM
jim_hoyland Call Ed at 1-2-3
(440) 668-8164
He’s the guru Jul 1 2025, 10:53 AM
wbgoggans
Call Ed at 1-2-3
(440) 668-8164
He’s the guru
... Jul 1 2025, 03:20 PM
FlacaProductions Yup. Install and rotate counter-clockwise juuuuus... Jul 1 2025, 04:05 PM
Robarabian What Flaca said... you don't just turn it... a... Jul 1 2025, 05:56 PM
dtmehall not to be a dinosaur, but this is a very similar p... Jul 1 2025, 08:56 PM
SteveNMaine I have the 123/TUNE+4-R-V-POR What should I be pro... Jul 2 2025, 04:37 AM
FlacaProductions Here's a note I have saved from Ian concerning... Jul 2 2025, 08:09 AM
SteveNMaine
Here's a note I have saved from Ian concernin... Jul 3 2025, 01:57 PM
SteveNMaine
[quote name='FlacaProductions' post='3212878' dat... Jul 3 2025, 06:18 PM
Superhawk996
I still have not been able to get my 2056 to star... Jul 3 2025, 09:17 AM
SteveNMaine
I still have not been able to get my 2056 to sta... Jul 4 2025, 09:50 AM
IronHillRestorations If it ran well before you pulled the distributor, ... Jul 3 2025, 09:38 AM
IronHillRestorations Make sure there’s a center contact in the distri... Jul 3 2025, 02:53 PM
emerygt350 Have you tried starting fluid?
Timing is just tim... Jul 3 2025, 06:34 PM
Stratfink Hang in there Steve. Several of us struggled to ge... Jul 3 2025, 11:12 PM
Superhawk996 Cool - glad you don’t want to give up just yet. ... Jul 4 2025, 10:26 AM
SteveNMaine
Cool - glad you don’t want to give up just yet.... Jul 4 2025, 06:58 PM
Superhawk996 The dizzy drive gear installation and proper posit... Jul 4 2025, 10:30 AM
SteveNMaine
The dizzy drive gear installation and proper posi... Jul 5 2025, 06:36 AM
cassmcentee Here is a pic of how mine is installed, I believe ... Jul 5 2025, 06:47 AM
Superhawk996
Looking at the installation page it says the tim... Jul 5 2025, 06:59 AM
Superhawk996 Sort of assumed you knew you’re getting fuel due... Jul 4 2025, 07:06 PM
SteveNMaine So, I removed the 123 dizzy and checked the drive ... Jul 5 2025, 08:51 AM
emerygt350 You need to be more descriptive than 'not star... Jul 5 2025, 10:37 AM
Superhawk996 Good job putting the dizzy drive to correct positi... Jul 5 2025, 10:59 AM
Superhawk996 Also have questions about the carbs.
1) Are thes... Jul 5 2025, 11:07 AM
iankarr Hang in there! As others have said, it will be... Jul 5 2025, 11:56 AM
SteveNMaine The carbs are brand new; linkage is hooked up to b... Jul 5 2025, 02:01 PM
Superhawk996
The carbs are brand new; linkage is hooked up to ... Jul 5 2025, 03:45 PM
OrangeBones It might be the fueling but if you can shoot video... Jul 5 2025, 06:02 PM
emerygt350 Engines start easier a little retarded on the timi... Jul 5 2025, 07:24 PM
IronHillRestorations I’m still not convinced that the timing is set a... Jul 6 2025, 06:43 AM
fixer34
I’m still not convinced that the timing is set ... Jul 6 2025, 11:55 AM
I’m still not convinced that the timing is set... Jul 6 2025, 07:01 PM
iankarr Is there a new cam in the engine? If so, I'd m... Jul 6 2025, 03:21 PM
SteveNMaine
Is there a new cam in the engine? If so, I'd ... Jul 7 2025, 04:34 AM
iankarr
Is there a new cam in the engine? If so, I'd... Jul 8 2025, 11:27 PM
Rob-O
I’m still not convinced that the timing is set ... Jul 6 2025, 06:07 PM
IronHillRestorations Take the driver side valve cover off and confirm b... Jul 6 2025, 08:23 PM
IronHillRestorations duplicate Jul 6 2025, 08:23 PM
emerygt350 If the cam is off a tooth or three it will. Jul 7 2025, 04:48 AM
SteveNMaine
Let... Jul 7 2025, 06:13 AM
emerygt350
Let... Jul 7 2025, 06:32 AM
SteveNMaine Last year I purchased a 1975 2.0 that had been rem... Jul 7 2025, 07:54 AM
emerygt350 I would still verify, just to be absolutely certai... Jul 7 2025, 08:10 AM
SteveNMaine
I would still verify, just to be absolutely certa... Jul 7 2025, 08:54 AM
Superhawk996 With all due respect - the advance curve has nothi... Jul 7 2025, 09:18 AM
SteveNMaine At TDC the valves 0n #1 are closed, timing marks o... Jul 7 2025, 12:10 PM
emerygt350 All that's left is spark and compression.... ... Jul 7 2025, 02:47 PM
Front yard mechanic I used the coil from 123 and have the model w/ no ... Jul 7 2025, 03:21 PM
SteveNMaine So, I spoke with Ed at 123 and he suggested cranki... Jul 7 2025, 06:37 PM
IronHillRestorations Good to hear you’ve got it to start :headbanger... Jul 7 2025, 08:11 PM
SteveNMaine So, the next puzzle is this; when the 123 is setup... Jul 9 2025, 05:34 AM
emerygt350
So, the next puzzle is this; when the 123 is setu... Jul 9 2025, 06:59 AM
VaccaRabite
So, the next puzzle is this; when the 123 is setu... Jul 9 2025, 04:15 PM
fixer34 I'm not familiar with the 123 unit, the 50yr o... Jul 9 2025, 07:09 AM
nditiz1 It is recommended to create a 0 degree file. Make... Jul 9 2025, 07:11 AM
emerygt350 I do this all the time. Not the 180 out but putti... Jul 9 2025, 06:23 PM
SteveNMaine So, what I discovered:
The plate under the rotor ... Jul 10 2025, 06:30 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th May 2026 - 03:06 AM |
