> How Stiff is Your Thing?
bkrantz
post Jun 22 2025, 06:43 PM
Mine is too stiff, I think. Oh, the thing I mean is the internal door latch mechanism. And the part that seems stiff is the locking function.
In case your never spent any intimate time with the mechanism, the locking function is done by a stamped plate that shifts up (to lock) and down (to unlock). I continue to have problems unlocking the doors with keys, even after Curt did his magic on the cylinders.
Since the up-down shift of the locking plate is accomplished by the little lever on the internal end of the cylinder, as twisted by the key, so it would seem to be better if the plate shifted without much resistance.
Oh, and I have tried some different lubes.
bkrantz
post Jul 10 2025, 07:50 PM
I pulled and twisted the spring (green arrow) so that it no longer traps the lock plate tab, and it also releases the torsion on the locking rod pivot.
bkrantz   How Stiff is Your Thing?   Jun 22 2025, 06:43 PM
76-914   Mine is too stiff, I think. Oh, the thing I mean...   Jun 22 2025, 07:07 PM
mlindner   I had the same problem for years. After I had the ...   Jun 23 2025, 08:02 AM
mmichalik   I had the same issue with my 75. I took the same ...   Jun 23 2025, 09:16 AM
bkrantz   Thanks, guys. Here is an annotated version of the...   Jun 23 2025, 11:29 AM
Chris914n6   You didn't say what you used to clean and grea...   Jun 23 2025, 12:20 PM
ClayPerrine   An addendum. About every 2 years or so I pull th...   Jun 23 2025, 12:59 PM
Artfrombama   An addendum. About every 2 years or so I pull t...   Jun 23 2025, 09:11 PM
Front yard mechanic   Not to soft but it sure is short   Jun 23 2025, 08:26 PM
bkrantz   OK, I decided to try some new ideas. First, I wil...   Jul 10 2025, 07:45 PM
bkrantz   I pulled and twisted the spring (green arrow) so t...   Jul 10 2025, 07:50 PM
bkrantz   Now the locking plate and tab (red arrow) can shif...   Jul 10 2025, 07:55 PM
bkrantz   The only friction for the locking plate now is the...   Jul 10 2025, 07:58 PM
bkrantz   My second innovation is to try a different lube st...   Jul 10 2025, 08:01 PM
bkrantz   Internal latch back in place. I did have to conne...   Jul 10 2025, 08:04 PM
bkrantz   External handle installed--and tested. Seems like...   Jul 10 2025, 08:08 PM
DRPHIL914   Frog lube huh? :blink: :blink: ok no comments ...   Jul 11 2025, 11:44 AM
bkrantz   Frog lube huh? :blink: :blink: ok no comments...   Jul 11 2025, 06:50 PM
Steve   I just spray the crap out of everything every 10 y...   Jul 12 2025, 11:02 AM
- Lo-Fi Version Time is now: 30th April 2026 - 02:28 PM
