Gatornapper |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,283 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States ![]() ![]() |
Once again need the help of the great 914 Brain Trust here........
My Parking Brake Light stays on all the time. The switch is fairly new and it is functioning properly. Disconnecting the brown (ground) wire to the switch, it has no continuity or resistance to ground. So it is not "grounded out" somewhere. I see in my great 914 electrical schematic of the ground circuit for the switch and light that there are two diodes in the circuit. I am guessing that one of them failed. Can anyone tell me where these two diodes are located? Or where else the problem might be? As always, TIA, GN |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,238 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
For the MC warning switch, you can disconnect the wires to see if the warning light goes out. Same with the ebrake switch. The flasher will flash with relatively little current through the switches or other leakage.
Gatornapper |
Thanks Spoke.
Light still flashes with brake wire disconnected. Gotta get under car to remove MC wire I guess.........yes, light flashes..... Is wire to MC looking for fluid in MC? Just bled my brakes and light still flashes. My 914 has 911 MC. Brakes work great, reservoir is full. GN For the MC warning switch, you can disconnect the wires to see if the warning light goes out. Same with the ebrake switch. The flasher will flash with relatively little current through the switches or other leakage. |
Lo-Fi Version | Time is now: 3rd September 2025 - 06:14 PM |
