| bkrantz |
Jun 22 2025, 06:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,675 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Mine is too stiff, I think. Oh, the thing I mean is the internal door latch mechanism. And the part that seems stiff is the locking function.
In case your never spent any intimate time with the mechanism, the locking function is done by a stamped plate that shifts up (to lock) and down (to unlock). I continue to have problems unlocking the doors with keys, even after Curt did his magic on the cylinders. Since the up-down shift of the locking plate is accomplished by the little lever on the internal end of the cylinder, as twisted by the key, so it would seem to be better if the plate shifted without much resistance. Oh, and I have tried some different lubes. Attached thumbnail(s) |
| Steve |
Jul 12 2025, 11:02 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,038 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I just spray the crap out of everything every 10 years while working the mechanisms with WD40. Never had a problem after 40+ years of ownership.
bkrantz How Stiff is Your Thing? Jun 22 2025, 06:43 PM
76-914
Mine is too stiff, I think. Oh, the thing I mean... Jun 22 2025, 07:07 PM
mlindner I had the same problem for years. After I had the ... Jun 23 2025, 08:02 AM
mmichalik I had the same issue with my 75. I took the same ... Jun 23 2025, 09:16 AM
bkrantz Thanks, guys. Here is an annotated version of the... Jun 23 2025, 11:29 AM
Chris914n6 You didn't say what you used to clean and grea... Jun 23 2025, 12:20 PM
ClayPerrine An addendum.
About every 2 years or so I pull th... Jun 23 2025, 12:59 PM
Artfrombama
An addendum.
About every 2 years or so I pull t... Jun 23 2025, 09:11 PM
Front yard mechanic Not to soft but it sure is short Jun 23 2025, 08:26 PM
bkrantz OK, I decided to try some new ideas.
First, I wil... Jul 10 2025, 07:45 PM
bkrantz I pulled and twisted the spring (green arrow) so t... Jul 10 2025, 07:50 PM
bkrantz Now the locking plate and tab (red arrow) can shif... Jul 10 2025, 07:55 PM
bkrantz The only friction for the locking plate now is the... Jul 10 2025, 07:58 PM
bkrantz My second innovation is to try a different lube st... Jul 10 2025, 08:01 PM
bkrantz Internal latch back in place. I did have to conne... Jul 10 2025, 08:04 PM
bkrantz External handle installed--and tested.
Seems like... Jul 10 2025, 08:08 PM
DRPHIL914 Frog lube huh? :blink: :blink:
ok no comments ... Jul 11 2025, 11:44 AM
bkrantz
ok no comments... Jul 11 2025, 06:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 02:26 PM |
