> RESOLVED noisy engine after over-rev
DC_neun_vierzehn
post Jul 13 2025, 06:14 AM
First, it's a '73 2.0 (2056 rebuild with about 1,000 miles on it). 123 dizzy. Car was driving great. No issues.
Then, last November, I over-rev'd my engine twice. First time due to forgetting to put the throttle body spring back on after reinstalling a new gasket under the TB. The second over-rev was immediately after because unbeknownst to me the throttle cable was tangled in at the pedal cluster due to omission of spring. Both times, I pulled the key out IMMEDIATELY, but not before I saw the tach needle shoot WELL past the red line. Both times my heart sank. Still beating myself up for the gaffes. Also frustrated that the rev limiter in my 123 dizzy settings didn't prevent the over-revving. Ed at 123 (great guy) said that rev limiter does not prevent the RPMs from going above the threshold it's set at, rather it prevents sustained RPMs beyond the limit. Ugggg.
First thing I did was look for leaks under motor, in the engine bay, check for any funny smells. Didn't see or smell anything. Next thing I did was take it for a nice and easy drive around the block. Drove fine, but I thought it sounded a little noisy. Next thing I did was take it for a slightly longer drive and slightly less nice and easy. Did not notice any loss of power or any difference it how it drove - just a little noisy. The best I can describe the sound it "loose" (thumpy ... chattery ... a little like a diesel engine).
Then winter came (snow, salty roads, etc.) and I put the car away for the winter and planned to dive in when spring came. For last several weeks, I've been diving in trying to find the culprit.
Here's what I've done so far.
1. Compression tested each cylinder. 3 were at 130. C4 was at 120.
2. Removed both valve covers. Inspected all rocker arms and springs. Everything looked fine. Checked valve lash. C1 and C2 both were in spec (.008 exhaust and .006 intake). However, C3 had .004 for both exhaust and intake, and C4 had .002 for exhaust and .009 for intake. I removed those rocker arms to inspect closer. Everything looked fine. Reinstalled the rocker arms and adjusted the valve lash to spec (matching C1 and C2).
3. Changed oil. Inspected all of the oil visually in a glass jar. Did not see any debris. I ran a magnet through each jar, no metal shavings or pieces on the magnet. I'm going to cut the oil filter open with tin snips later today to see if I see anything in there. Topped her off with 3.5 quarts of fresh oil and new filter.
4. Took a 10 mile test drive. Noises are still there. Uggggg.
5. Removed valve covers. Checked the valve lash. Everything still in spec. Nothing moved.
What could be causing the noise?
The car definitely sounds different since the over-revs. I'll try to post links to a few short vids with audio.
GregAmy
post Jul 14 2025, 09:34 AM
I use this for engine inspections, quite handy. WiFi to my iPad or iPhone. Might want to see what replaced it.
https://www.amazon.com/dp/B01MYTHWK4
DC_neun_vierzehn   RESOLVED noisy engine after over-rev   Jul 13 2025, 06:14 AM
DC_neun_vierzehn   https://youtube.com/shorts/_XfSF5G5078?si=f6K6KNL_...   Jul 13 2025, 06:31 AM
bdstone914   https://youtube.com/shorts/_XfSF5G5078?si=f6K6KNL...   Jul 13 2025, 06:39 AM
DC_neun_vierzehn   [quote name='DC_neun_vierzehn' post='3214676' dat...   Jul 13 2025, 09:56 AM
bdstone914   Bent pushrod(s) ? Pull them and roll on a flat su...   Jul 13 2025, 06:31 AM
Puebloswatcop   Bent pushrod(s) ? Pull them and roll on a flat s...   Jul 13 2025, 06:43 AM
DC_neun_vierzehn   Bent pushrod(s) ? Pull them and roll on a flat s...   Jul 13 2025, 10:03 AM
Dave_Darling   ... I was able to pull the push rod out below the ...   Jul 13 2025, 06:24 PM
DC_neun_vierzehn   ... I was able to pull the push rod out below the...   Jul 14 2025, 07:43 AM
DC_neun_vierzehn   ... I was able to pull the push rod out below the...   Jul 17 2025, 07:18 AM
DC_neun_vierzehn   [quote name='DC_neun_vierzehn' post='3214702' da...   Jul 18 2025, 01:45 PM
GregAmy   Hoping someone can share the torque LB for the roc...   Jul 18 2025, 01:54 PM
DC_neun_vierzehn   [quote name='DC_neun_vierzehn' post='3215591' dat...   Jul 18 2025, 03:26 PM
930cabman   Hoping someone can share the torque LB for the ro...   Jul 18 2025, 06:12 PM
emerygt350   [quote name='GregAmy' post='3215592' date='Jul 18...   Jul 18 2025, 06:46 PM
Ishley   I don’t hear anything loud… but it’s hard to...   Jul 13 2025, 08:36 AM
mepstein   I would do a leak down test.   Jul 13 2025, 08:49 AM
JamesM   I would do a leak down test. :agree: Now that...   Jul 13 2025, 10:03 AM
stownsen914   If you have rev limiter set (and it's actually...   Jul 13 2025, 10:32 AM
DC_neun_vierzehn   If you have rev limiter set (and it's actuall...   Jul 13 2025, 03:24 PM
GregAmy   Now that you have the valves adjusted back to spec...   Jul 13 2025, 01:40 PM
DC_neun_vierzehn   I would do a leak down test. Ok. Never done one...   Jul 13 2025, 03:34 PM
mepstein   I would do a leak down test. Ok. Never done on...   Jul 13 2025, 05:37 PM
IronHillRestorations   Have you checked the alternator and impeller? Doe...   Jul 13 2025, 12:15 PM
DC_neun_vierzehn   Have you checked the alternator and impeller? Do...   Jul 13 2025, 03:27 PM
Shivers   @DC_neun_vierzehn A broken valve spring can make...   Jul 13 2025, 03:41 PM
DC_neun_vierzehn   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 14 2025, 07:55 AM
914sgofast2   Harbor Freight sells leak down gauges, as well as ...   Jul 13 2025, 06:21 PM
930cabman   Harbor Freight sells leak down gauges, as well as...   Jul 17 2025, 06:12 AM
emerygt350   Definitely do the stethoscope to find a cylinder b...   Jul 13 2025, 07:15 PM
DC_neun_vierzehn   Are you certain you are getting the clearance cor...   Jul 14 2025, 07:53 AM
infraredcalvin   Even if it’s a bent pushrod or broken spring, th...   Jul 13 2025, 11:37 PM
emerygt350   A cheap boroscope from Amazon might be a good thin...   Jul 14 2025, 04:49 AM
mepstein   A cheap boroscope from Amazon might be a good thi...   Jul 14 2025, 05:36 AM
DC_neun_vierzehn   A cheap boroscope from Amazon might be a good th...   Jul 14 2025, 07:57 AM
emerygt350   Super easy. The cheap boroscopes have an app that...   Jul 14 2025, 09:01 AM
DC_neun_vierzehn   Super easy. The cheap boroscopes have an app tha...   Jul 14 2025, 01:55 PM
emerygt350   Super easy. The cheap boroscopes have an app th...   Jul 14 2025, 07:01 PM
GregAmy   I use this for engine inspections, quite handy. Wi...   Jul 14 2025, 09:34 AM
iankarr   My take on the Krusty method is that it's grea...   Jul 14 2025, 07:35 PM
DC_neun_vierzehn   I decided to start with the scoping first. Here ar...   Jul 17 2025, 11:46 AM
emerygt350   I don't see anything that looks like damage, b...   Jul 17 2025, 12:06 PM
WFG   Could be a cracked piston at the pin. Happened to ...   Jul 17 2025, 12:59 PM
emerygt350   You localized the sound to cyl 4? Maybe time to r...   Jul 17 2025, 02:22 PM
DC_neun_vierzehn   You localized the sound to cyl 4? Maybe time to ...   Jul 17 2025, 03:09 PM
emerygt350   It's just that you can't mess up the crust...   Jul 17 2025, 06:51 PM
GregAmy   Cap'n Krusty Method fan here, especially with ...   Jul 18 2025, 05:13 AM
TheCabinetmaker   Plus 1 on the chromolly pushrods and 911 adjusters...   Jul 18 2025, 07:43 AM
emerygt350   I like rolling the wheels in 5th, just seems less ...   Jul 18 2025, 09:24 AM
DC_neun_vierzehn   So I wasn't crazy when I posted earlier that I...   Jul 18 2025, 02:38 PM
Shivers   So I wasn't crazy when I posted earlier that ...   Jul 18 2025, 04:27 PM
DC_neun_vierzehn   You don’t need much. Undo the two large bolts o...   Jul 19 2025, 07:46 AM
Shivers   [quote name='Shivers' post='3215621' date='Jul 18...   Jul 19 2025, 08:20 AM
emerygt350   Yeah it's not much.   Jul 18 2025, 03:38 PM
Jack Standz   Unseat the pushrod tube by a twisting force and pu...   Jul 18 2025, 05:52 PM
Jack Standz   These damage the pushrod tubes less: https://www....   Jul 18 2025, 05:57 PM
Jack Standz   Obviously, put new pushrods tube o-rings (they...   Jul 18 2025, 07:05 PM
DC_neun_vierzehn   Well boys … didn’t go as planned today. I lo...   Jul 19 2025, 03:28 PM
emerygt350   Hmm, I thought it would go a hair lower without di...   Jul 19 2025, 03:30 PM
DC_neun_vierzehn   Hmm, I thought it would go a hair lower without d...   Jul 19 2025, 03:38 PM
DC_neun_vierzehn   Did you recheck the clearances? Apologies for t...   Jul 19 2025, 03:39 PM
emerygt350   Did you recheck the clearances? Apologies for ...   Jul 19 2025, 05:14 PM
DC_neun_vierzehn   [quote name='DC_neun_vierzehn' post='3215753' dat...   Jul 19 2025, 05:38 PM
mepstein   Just drop the engine and trans.   Jul 19 2025, 03:48 PM
930cabman   Just drop the engine and trans. :agree:   Jul 19 2025, 04:50 PM
emerygt350   Are you doing .008 and .006?   Jul 19 2025, 06:11 PM
DC_neun_vierzehn   Are you doing .008 and .006? Correct.   Jul 19 2025, 06:32 PM
emerygt350   When the valves on four are completely compressed ...   Jul 19 2025, 07:37 PM
DC_neun_vierzehn   When the valves on four are completely compressed...   Jul 20 2025, 10:25 AM
emerygt350   Truthfully if you have valve train damage you shou...   Jul 19 2025, 07:40 PM
DC_neun_vierzehn   Truthfully if you have valve train damage you sho...   Jul 20 2025, 10:27 AM
emerygt350   [quote name='emerygt350' post='3215771' date='Jul...   Jul 20 2025, 11:54 AM
Jack Standz   You've already got the valve cover off and the...   Jul 20 2025, 10:47 AM
rjames   If you can’t get the pushrod out, it looks to me...   Jul 20 2025, 02:26 PM
DC_neun_vierzehn   So I thought before I attempt to remove the pushro...   Jul 26 2025, 11:16 AM
tomeric914   Kris, The cam in that motor is a Webcam 73 grind....   Jul 26 2025, 08:14 PM
DC_neun_vierzehn   Kris, The cam in that motor is a Webcam 73 grind...   Jul 28 2025, 07:27 AM
Jack Standz   Looks like a likely suspect. Maybe the valve/sea...   Jul 26 2025, 12:59 PM
emerygt350   Interesting! Valve stems stretch but that...   Jul 26 2025, 01:35 PM
Jack Standz   Would still perform a leak down test, especially o...   Jul 28 2025, 09:56 AM
DC_neun_vierzehn   Would still perform a leak down test, especially ...   Jul 29 2025, 08:09 AM
emerygt350   Also... If you are worried perhaps you haven't...   Jul 28 2025, 08:46 PM
DC_neun_vierzehn   Also... If you are worried perhaps you haven...   Jul 29 2025, 08:11 AM
emerygt350   That might hint at over tight valves before....   Jul 29 2025, 12:39 PM
DC_neun_vierzehn   Hoping someone can help - which # is the correct p...   Aug 8 2025, 10:55 AM
emerygt350   Wish I knew... Maybe check autoatlanta and see wh...   Aug 8 2025, 10:58 AM
Jack Standz   Do you have 8mm or 10mm adjusters? Personally, w...   Aug 8 2025, 03:08 PM
DC_neun_vierzehn   Do you have 8mm or 10mm adjusters? Personally, ...   Aug 8 2025, 06:02 PM
Dave_Darling   039 part numbers are for 2.0 engines, almost unive...   Aug 8 2025, 05:56 PM
DC_neun_vierzehn   039 part numbers are for 2.0 engines, almost univ...   Aug 8 2025, 06:05 PM
DC_neun_vierzehn   Noisy engine resolved, thanks to @BeatNavy . Issu...   May 11 2026, 02:09 PM
7 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 11th May 2026 - 04:10 PM
