sixaddict |
Senior Member ![]() ![]() ![]() Group: Members Posts: 956 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States ![]() ![]() |
Stoddard has pre bent brake line kit in galvanized or “ green”.
If you want “correct” assuming you stay with galvanized. Comments? |
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 513 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
If you go with stainless steel(availablefrom PMB), understand that these lines are harder. Put a set on a few weeks ago and had to really tighten them before they stopped leaking. Unless you plan on racing or Very heavy braking, the standard steel lines are just fine The standard tin coated steel lines work fine. But, the stainless ones do not corrode over time (especially with hygroscopic brake fluids), look cool and are less expensive than the green ones. |
Lo-Fi Version | Time is now: 15th July 2025 - 06:02 PM |
