> Brain Trust Help needed on Parking Brake Light, Parking Brake Light Always on......
Gatornapper
post Jul 4 2025, 07:40 PM
Once again need the help of the great 914 Brain Trust here........
My Parking Brake Light stays on all the time.
The switch is fairly new and it is functioning properly.
Disconnecting the brown (ground) wire to the switch, it has no continuity or resistance to ground. So it is not "grounded out" somewhere.
I see in my great 914 electrical schematic of the ground circuit for the switch and light that there are two diodes in the circuit.
I am guessing that one of them failed.
Can anyone tell me where these two diodes are located?
Or where else the problem might be?
As always,
TIA,
GN
Literati914
post Jul 17 2025, 12:35 PM
I have the same issue with the stupid flashing light caused by the M.C., I’ve unplugged it’s wire from the bulb for the time being (e-brake still causes it to flash as it should when up).
I’d say ‘don’t be surprised if there is no reset button to push’ … I have 3 old 914 master cylinders and none of them have a reset button. Am I missing something? They all have some type of a square plastic “tower” where the spade(s) are … is that somehow the reset “button”? I lightly tried prying the plastic block off on one and that didn’t seem to be the case (IMG:style_emoticons/default/confused24.gif)
In the pic below, the separate warning switch does actually have a button (under a little cover that's meant to be temporarily removed). I switched it out for a two-spade switch before installing my 914rubber after-market MC and am now wondering if there's maybe a compatibility issue.. did so because my car has an obvious ground wire in that location for the MC. I think I’m gonna try going back to the single spade unit and see if I can get the light to stop blinking.
Gatornapper
post Jul 17 2025, 07:28 PM
Thanks.
Gonna unplug mine - if there is one. My MC is from a 911 - does that one have same reset button and wire?
I'll just monitor my brakes and brake fluid level closely. No need for warning light.
E-Brake switch is another matter - too many times I've driven off with E-brake on!
GN
QUOTE(Literati914 @ Jul 17 2025, 12:35 PM) *
Gatornapper   Brain Trust Help needed on Parking Brake Light   Jul 4 2025, 07:40 PM
jim_hoyland   MC ? I just went through this… :)   Jul 4 2025, 08:41 PM
Jamie   MC ? I just went through this… :) I'm also...   Jul 5 2025, 09:03 AM
Superhawk996   I'm also trying to troubleshoot the flashing...   Jul 5 2025, 12:25 PM
Literati914   @Gatornapper - if you pull the combo gauge, you...   Jul 5 2025, 10:01 AM
Gatornapper   Ah yes! On my schematic it does look like one...   Jul 5 2025, 10:47 AM
BillC   What is "MC"? "MC" is short ...   Jul 5 2025, 11:05 AM
Literati914   What is "MC"? "MC" is short...   Jul 5 2025, 12:10 PM
Superhawk996   Simplified schematic from Spoke   Jul 5 2025, 12:23 PM
Gatornapper   Ah, yes. Thank you SH for the schematic. NO diod...   Jul 9 2025, 05:44 AM
Spoke   For the MC warning switch, you can disconnect the ...   Jul 9 2025, 06:36 AM
Gatornapper   Thanks Spoke. Light still flashes with brake wire...   Jul 11 2025, 06:41 AM
914   Is there a reset button/Switch on the Master Cyl? ...   Jul 11 2025, 07:23 AM
Jamie   Is there a reset button/Switch on the Master Cyl?...   Jul 11 2025, 08:55 AM
Gatornapper   I'll do the same. Lift presently occupied pre...   Jul 14 2025, 03:14 PM
Superhawk996   What in the world does this wire to the MC do? ...   Jul 14 2025, 05:47 PM
Gatornapper   SH - Have electrical schematics for '87 944? ...   Jul 20 2025, 01:56 PM
Superhawk996   SH - Have electrical schematics for '87 944?...   Jul 20 2025, 02:38 PM
Cairo94507   On my MC there is- ATE. :beer2:   Jul 11 2025, 08:06 AM
Gatornapper   Change of subject as I have no where else to go: ...   Jul 17 2025, 06:07 AM
Literati914   I have the same issue with the stupid flashing lig...   Jul 17 2025, 12:35 PM
Gatornapper   Thanks. Gonna unplug mine - if there is one. My ...   Jul 17 2025, 07:28 PM
Superhawk996   No need for warning light. :blink: :headbang...   Jul 17 2025, 10:18 PM
Superhawk996   I’d say ‘don’t be surprised if there is n...   Jul 17 2025, 10:14 PM
Literati914   I’d say ‘don’t be surprised if there is ...   Jul 21 2025, 08:12 AM
Superhawk996   [quote name='Literati914' post='3215412' date='J...   Jul 21 2025, 10:13 AM
Literati914   .. [i]They all have some type of a square plastic...   Jul 21 2025, 04:01 PM
Superhawk996   Were there EARLY two-pole switches with manual b...   Jul 21 2025, 04:27 PM
Lucky9146   Finding this thread helpful in diagnosing my own s...   Jul 21 2025, 08:58 PM
Gatornapper   Finally got car on lift to find that there was no ...   Sep 2 2025, 07:58 AM
Spoke   Finally got car on lift to find that there was no...   Sep 2 2025, 08:54 AM
- Lo-Fi Version Time is now: 3rd September 2025 - 06:14 PM
