> 123 Distributor vacuum advance set up and curve, Advise on seting up the vacuum advance curve on 123 distributor
Clydeskeeper
post Jul 15 2025, 01:10 PM
I have searched the forum and watched too many YouTube videos. I am either missing the answer or just don't quite understand.
I am replacing my distributor with a Bluetooth 123. I am a little confused on setting up the vacuum advance curve and maybe even the mechanical curve. On a basic level, I understand that it needs to go from a static of 10 degree at idle up to 27 or even a little more at 3,500 rpm's. Of the videos I have watched, seems like most are not even using the vacuum advance part and just using the mechanical to achieve the above curve. Others go into details I just don't understand including using the vacuum to retard the timing at certain rpm's.
Is there a simple answer and old guy like me can understand? I grew up with cars that actually had mechanical distributors with points and carburetors for fuel delivery. So these concepts are not completely foreign to me.
Just for reference, the engine in question is a modified 2 liter that is now 2549cc with dual 48 Webers.
I await your thoughts, should be interesting at always.
Robert!
emerygt350
post Jul 16 2025, 05:03 AM
I use setting 1, seems to do well for my engine. I have ported vacuum and use the vacuum advance.
The problem with the retard is the original design was supposed to fight the advance, then in late 74 or something they dumped the advance and that was lost. Then to compound that the 123 retard is on or off and sensitive to the slightest vacuum (I think I measured it turning on the retard with as little as 3 inhg. Probably less. Your retard port on the Tb can see that at cruise and even when you start cracking the throttle. I found my car was retarding the timing at all the wrong moments. The original wouldn't have reacted or at least reacted much to such a small signal.
It will reduce your idle of course but my car is at 8 degrees at idle with my leaky idle screw all the way in and idles at 900. I could go lower if I didn't have a leaking idle screw.
rjames
post Jul 16 2025, 09:27 AM
I'm made of metal
QUOTE(emerygt350 @ Jul 16 2025, 04:03 AM) *
Thanks for the response. I may have to try setting '2' and see if I notice a difference.
wonkipop
post Jul 17 2025, 08:31 PM
QUOTE(rjames @ Jul 16 2025, 09:27 AM) *
i'm taking an educated guess here re those two advance curves.
what i think it will be is the EC-A versus EC-B thing of the 74 L Jets.
EC-B engines for the 49 states used the vac port above the throttle plate and the hose was hooked up to the advance side of the dual action vac can on the distributor.
the vac port below the throttle plate was hooked up the retard side of the dual action can (green hose originally).
the EC-B (for california) had the advance hose disconnected from the throttle body and the hose was tucked under the plenum. the port on the throttle body was capped.
same distributor, same ECU, same AFM on both the EC-A and EC-B.
in 75 neither the 49 state 1.8 or the california 1.8 connected the advance can on the distributor to anything. the californian cars had the vac port above the throttle plate connected to an EGR. so 75 1.8 same as 74 1.8 california. no vac advance.
same distributor, same ECU, same AFM.
the way it worked is:
EC-B.
retarded timing at idle - purely through action of retard side of can.
advanced timing at cruise - through action of vac advance - vac retard = true vac advance. the port above the throttle plate influenced the advance side of can.
but at the same time the port below the t plate influenced the negative side of can.
net result was the desired vac advance at cruise.
EC-A
retarded timing at idle.
retarded timing at cruise.
the 49 state car was required to reduced NOX emissions at stand still idle.
the californian car was required to reduced NOX emissions at standstill idle and also at freeway/highway cruise. the retarded timing did that.
power output is not really affected in either instance. there is no vacuum acting on the timing under throttle. purely mech advance.
i am not sure if the 75 ECU settings are suited to "restoring" the lack of vac advance originally.
but certainly the 74 1.8s can be run either way. simply a matter of connecting the hose or disconnecting it.
the car runs better with the hose and vac advance connected when at highway cruise.
for a 74 you would definitely choose the first of the advance curves.
i believe there is good chance the second of those settings mimics the 74 california and the 75 49states/california stock settings.
- Lo-Fi Version Time is now: 19th July 2025 - 02:14 AM
