Gatornapper |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,283 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States ![]() ![]() |
Once again need the help of the great 914 Brain Trust here........
My Parking Brake Light stays on all the time. The switch is fairly new and it is functioning properly. Disconnecting the brown (ground) wire to the switch, it has no continuity or resistance to ground. So it is not "grounded out" somewhere. I see in my great 914 electrical schematic of the ground circuit for the switch and light that there are two diodes in the circuit. I am guessing that one of them failed. Can anyone tell me where these two diodes are located? Or where else the problem might be? As always, TIA, GN |
Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,087 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
I have the same issue with the stupid flashing light caused by the M.C., I’ve unplugged it’s wire from the bulb for the time being (e-brake still causes it to flash as it should when up).
I’d say ‘don’t be surprised if there is no reset button to push’ … I have 3 old 914 master cylinders and none of them have a reset button. Am I missing something? They all have some type of a square plastic “tower” where the spade(s) are … is that somehow the reset “button”? I lightly tried prying the plastic block off on one and that didn’t seem to be the case (IMG:style_emoticons/default/confused24.gif) In the pic below, the separate warning switch does actually have a button (under a little cover that's meant to be temporarily removed). I switched it out for a two-spade switch before installing my 914rubber after-market MC and am now wondering if there's maybe a compatibility issue.. did so because my car has an obvious ground wire in that location for the MC. I think I’m gonna try going back to the single spade unit and see if I can get the light to stop blinking. Attached thumbnail(s) ![]() |
Gatornapper |
Thanks.
Gonna unplug mine - if there is one. My MC is from a 911 - does that one have same reset button and wire? I'll just monitor my brakes and brake fluid level closely. No need for warning light. E-Brake switch is another matter - too many times I've driven off with E-brake on! GN I have the same issue with the stupid flashing light caused by the M.C., I’ve unplugged it’s wire from the bulb for the time being (e-brake still causes it to flash as it should when up). I’d say ‘don’t be surprised if there is no reset button to push’ … I have 3 old 914 master cylinders and none of them have a reset button. Am I missing something? They all have some type of a square plastic “tower” where the spade(s) are … is that somehow the reset “button”? I lightly tried prying the plastic block off on one and that didn’t seem to be the case (IMG:style_emoticons/default/confused24.gif) In the pic below, the separate warning switch does actually have a button (under a little cover that's meant to be temporarily removed). I switched it out for a two-spade switch before installing my 914rubber after-market MC and am now wondering if there's maybe a compatibility issue.. did so because my car has an obvious ground wire in that location for the MC. I think I’m gonna try going back to the single spade unit and see if I can get the light to stop blinking. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,360 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
No need for warning light. (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/screwy.gif) |
Lo-Fi Version | Time is now: 3rd September 2025 - 06:08 PM |
