mharrison |
Why do I bother???? ![]() ![]() ![]() Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 ![]() |
Well, when I went out to rewire the fuel pump today I discovered that the rust under the passenger side was worse than expected. (Honestly, I've been scared to poke at it with a screwdriver.)
The Jack pad on the underside of the car was bad when I got the car, but I thought that was the extent of it. Today while poking at the rust here is what I uncovered. (IMG:http://home.jam.rr.com/mharrison/914Resto/Rust/Inside%20the%20hole.JPG) |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
Just do it right and you wont be that guy. I have to pull the rockers on the 74 and check out underneath them. I may wind up reinforcing them just to be safe. If I do, I will document every step of it and post it so you can see what I do and decide if that is what you want also. Everthing I do will be from common stuff you can get locally. I wont be buying any body panels or replacement panels from anyone. I will make everything myself.
Lo-Fi Version | Time is now: 12th July 2025 - 03:09 PM |
