| DC_neun_vierzehn |
Jul 13 2025, 06:14 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 654 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
First, it's a '73 2.0 (2056 rebuild with about 1,000 miles on it). 123 dizzy. Car was driving great. No issues.
Then, last November, I over-rev'd my engine twice. First time due to forgetting to put the throttle body spring back on after reinstalling a new gasket under the TB. The second over-rev was immediately after because unbeknownst to me the throttle cable was tangled in at the pedal cluster due to omission of spring. Both times, I pulled the key out IMMEDIATELY, but not before I saw the tach needle shoot WELL past the red line. Both times my heart sank. Still beating myself up for the gaffes. Also frustrated that the rev limiter in my 123 dizzy settings didn't prevent the over-revving. Ed at 123 (great guy) said that rev limiter does not prevent the RPMs from going above the threshold it's set at, rather it prevents sustained RPMs beyond the limit. Ugggg. First thing I did was look for leaks under motor, in the engine bay, check for any funny smells. Didn't see or smell anything. Next thing I did was take it for a nice and easy drive around the block. Drove fine, but I thought it sounded a little noisy. Next thing I did was take it for a slightly longer drive and slightly less nice and easy. Did not notice any loss of power or any difference it how it drove - just a little noisy. The best I can describe the sound it "loose" (thumpy ... chattery ... a little like a diesel engine). Then winter came (snow, salty roads, etc.) and I put the car away for the winter and planned to dive in when spring came. For last several weeks, I've been diving in trying to find the culprit. Here's what I've done so far. 1. Compression tested each cylinder. 3 were at 130. C4 was at 120. 2. Removed both valve covers. Inspected all rocker arms and springs. Everything looked fine. Checked valve lash. C1 and C2 both were in spec (.008 exhaust and .006 intake). However, C3 had .004 for both exhaust and intake, and C4 had .002 for exhaust and .009 for intake. I removed those rocker arms to inspect closer. Everything looked fine. Reinstalled the rocker arms and adjusted the valve lash to spec (matching C1 and C2). 3. Changed oil. Inspected all of the oil visually in a glass jar. Did not see any debris. I ran a magnet through each jar, no metal shavings or pieces on the magnet. I'm going to cut the oil filter open with tin snips later today to see if I see anything in there. Topped her off with 3.5 quarts of fresh oil and new filter. 4. Took a 10 mile test drive. Noises are still there. Uggggg. 5. Removed valve covers. Checked the valve lash. Everything still in spec. Nothing moved. What could be causing the noise? The car definitely sounds different since the over-revs. I'll try to post links to a few short vids with audio. |
| Jack Standz |
Jul 28 2025, 09:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 784 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Would still perform a leak down test, especially on #4 where that suspect adjuster was.
Another possibility is that the adjuster was set with way too much valve lash. If there was too much on that adjuster, it will cause more noise. Also, it might cause the marks on the adjuster face from the excessive pounding. What's the end of the valve look like for that adjuster? |
DC_neun_vierzehn RESOLVED noisy engine after over-rev Jul 13 2025, 06:14 AM
DC_neun_vierzehn https://youtube.com/shorts/_XfSF5G5078?si=f6K6KNL_... Jul 13 2025, 06:31 AM
bdstone914
https://youtube.com/shorts/_XfSF5G5078?si=f6K6KNL... Jul 13 2025, 06:39 AM
DC_neun_vierzehn
[quote name='DC_neun_vierzehn' post='3214676' dat... Jul 13 2025, 09:56 AM
bdstone914 Bent pushrod(s) ?
Pull them and roll on a flat su... Jul 13 2025, 06:31 AM
Puebloswatcop
Bent pushrod(s) ?
Pull them and roll on a flat s... Jul 13 2025, 06:43 AM
DC_neun_vierzehn
Bent pushrod(s) ?
Pull them and roll on a flat s... Jul 13 2025, 10:03 AM
Dave_Darling ... I was able to pull the push rod out below the ... Jul 13 2025, 06:24 PM
DC_neun_vierzehn
... I was able to pull the push rod out below the... Jul 14 2025, 07:43 AM
DC_neun_vierzehn
... I was able to pull the push rod out below the... Jul 17 2025, 07:18 AM
DC_neun_vierzehn
[quote name='DC_neun_vierzehn' post='3214702' da... Jul 18 2025, 01:45 PM
GregAmy Hoping someone can share the torque LB for the roc... Jul 18 2025, 01:54 PM
DC_neun_vierzehn
[quote name='DC_neun_vierzehn' post='3215591' dat... Jul 18 2025, 03:26 PM
930cabman
Hoping someone can share the torque LB for the ro... Jul 18 2025, 06:12 PM
emerygt350
[quote name='GregAmy' post='3215592' date='Jul 18... Jul 18 2025, 06:46 PM
Ishley I don’t hear anything loud… but it’s hard to... Jul 13 2025, 08:36 AM
mepstein I would do a leak down test. Jul 13 2025, 08:49 AM
JamesM
:agree:
Now that... Jul 13 2025, 10:03 AM
stownsen914 If you have rev limiter set (and it's actually... Jul 13 2025, 10:32 AM
DC_neun_vierzehn
If you have rev limiter set (and it's actuall... Jul 13 2025, 03:24 PM
GregAmy Now that you have the valves adjusted back to spec... Jul 13 2025, 01:40 PM
DC_neun_vierzehn
Ok. Never done one... Jul 13 2025, 03:34 PM
Ok. Never done on... Jul 13 2025, 05:37 PM
IronHillRestorations Have you checked the alternator and impeller? Doe... Jul 13 2025, 12:15 PM
DC_neun_vierzehn
Have you checked the alternator and impeller? Do... Jul 13 2025, 03:27 PM
Shivers @DC_neun_vierzehn
A broken valve spring can make... Jul 13 2025, 03:41 PM
DC_neun_vierzehn
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 14 2025, 07:55 AM
914sgofast2 Harbor Freight sells leak down gauges, as well as ... Jul 13 2025, 06:21 PM
930cabman
Harbor Freight sells leak down gauges, as well as... Jul 17 2025, 06:12 AM
emerygt350 Definitely do the stethoscope to find a cylinder b... Jul 13 2025, 07:15 PM
DC_neun_vierzehn
Are you certain you are getting the clearance cor... Jul 14 2025, 07:53 AM
infraredcalvin Even if it’s a bent pushrod or broken spring, th... Jul 13 2025, 11:37 PM
emerygt350 A cheap boroscope from Amazon might be a good thin... Jul 14 2025, 04:49 AM
A cheap boroscope from Amazon might be a good thi... Jul 14 2025, 05:36 AM
DC_neun_vierzehn
A cheap boroscope from Amazon might be a good th... Jul 14 2025, 07:57 AM
emerygt350 Super easy. The cheap boroscopes have an app that... Jul 14 2025, 09:01 AM
DC_neun_vierzehn
Super easy. The cheap boroscopes have an app tha... Jul 14 2025, 01:55 PM
emerygt350
Super easy. The cheap boroscopes have an app th... Jul 14 2025, 07:01 PM
GregAmy I use this for engine inspections, quite handy. Wi... Jul 14 2025, 09:34 AM
iankarr My take on the Krusty method is that it's grea... Jul 14 2025, 07:35 PM
DC_neun_vierzehn I decided to start with the scoping first. Here ar... Jul 17 2025, 11:46 AM
emerygt350 I don't see anything that looks like damage, b... Jul 17 2025, 12:06 PM
WFG Could be a cracked piston at the pin. Happened to ... Jul 17 2025, 12:59 PM
emerygt350 You localized the sound to cyl 4? Maybe time to r... Jul 17 2025, 02:22 PM
DC_neun_vierzehn
You localized the sound to cyl 4? Maybe time to ... Jul 17 2025, 03:09 PM
emerygt350 It's just that you can't mess up the crust... Jul 17 2025, 06:51 PM
GregAmy Cap'n Krusty Method fan here, especially with ... Jul 18 2025, 05:13 AM
TheCabinetmaker Plus 1 on the chromolly pushrods and 911 adjusters... Jul 18 2025, 07:43 AM
emerygt350 I like rolling the wheels in 5th, just seems less ... Jul 18 2025, 09:24 AM
DC_neun_vierzehn So I wasn't crazy when I posted earlier that I... Jul 18 2025, 02:38 PM
Shivers
So I wasn't crazy when I posted earlier that ... Jul 18 2025, 04:27 PM
DC_neun_vierzehn
You don’t need much. Undo the two large bolts o... Jul 19 2025, 07:46 AM
Shivers
[quote name='Shivers' post='3215621' date='Jul 18... Jul 19 2025, 08:20 AM
emerygt350 Yeah it's not much. Jul 18 2025, 03:38 PM
Jack Standz Unseat the pushrod tube by a twisting force and pu... Jul 18 2025, 05:52 PM
Jack Standz These damage the pushrod tubes less:
https://www.... Jul 18 2025, 05:57 PM
Jack Standz Obviously, put new pushrods tube o-rings (they... Jul 18 2025, 07:05 PM
DC_neun_vierzehn Well boys … didn’t go as planned today.
I lo... Jul 19 2025, 03:28 PM
emerygt350 Hmm, I thought it would go a hair lower without di... Jul 19 2025, 03:30 PM
DC_neun_vierzehn
Hmm, I thought it would go a hair lower without d... Jul 19 2025, 03:38 PM
DC_neun_vierzehn Did you recheck the clearances?
Apologies for t... Jul 19 2025, 03:39 PM
emerygt350
Apologies for ... Jul 19 2025, 05:14 PM
DC_neun_vierzehn
[quote name='DC_neun_vierzehn' post='3215753' dat... Jul 19 2025, 05:38 PM
mepstein Just drop the engine and trans. Jul 19 2025, 03:48 PM
930cabman
:agree: Jul 19 2025, 04:50 PM
emerygt350 Are you doing .008 and .006? Jul 19 2025, 06:11 PM
DC_neun_vierzehn
Correct. Jul 19 2025, 06:32 PM
emerygt350 When the valves on four are completely compressed ... Jul 19 2025, 07:37 PM
DC_neun_vierzehn
When the valves on four are completely compressed... Jul 20 2025, 10:25 AM
emerygt350 Truthfully if you have valve train damage you shou... Jul 19 2025, 07:40 PM
DC_neun_vierzehn
Truthfully if you have valve train damage you sho... Jul 20 2025, 10:27 AM
emerygt350
[quote name='emerygt350' post='3215771' date='Jul... Jul 20 2025, 11:54 AM
Jack Standz You've already got the valve cover off and the... Jul 20 2025, 10:47 AM
rjames If you can’t get the pushrod out, it looks to me... Jul 20 2025, 02:26 PM
DC_neun_vierzehn So I thought before I attempt to remove the pushro... Jul 26 2025, 11:16 AM
tomeric914 Kris,
The cam in that motor is a Webcam 73 grind.... Jul 26 2025, 08:14 PM
DC_neun_vierzehn
Kris,
The cam in that motor is a Webcam 73 grind... Jul 28 2025, 07:27 AM
Jack Standz Looks like a likely suspect. Maybe the valve/sea... Jul 26 2025, 12:59 PM
emerygt350 Interesting! Valve stems stretch but that... Jul 26 2025, 01:35 PM
DC_neun_vierzehn
Would still perform a leak down test, especially ... Jul 29 2025, 08:09 AM
emerygt350 Also... If you are worried perhaps you haven't... Jul 28 2025, 08:46 PM
DC_neun_vierzehn
Also... If you are worried perhaps you haven... Jul 29 2025, 08:11 AM
emerygt350 That might hint at over tight valves before.... Jul 29 2025, 12:39 PM
DC_neun_vierzehn Hoping someone can help - which # is the correct p... Aug 8 2025, 10:55 AM
emerygt350 Wish I knew... Maybe check autoatlanta and see wh... Aug 8 2025, 10:58 AM
Jack Standz Do you have 8mm or 10mm adjusters?
Personally, w... Aug 8 2025, 03:08 PM
DC_neun_vierzehn
Personally, ... Aug 8 2025, 06:02 PM
Dave_Darling 039 part numbers are for 2.0 engines, almost unive... Aug 8 2025, 05:56 PM
DC_neun_vierzehn
039 part numbers are for 2.0 engines, almost univ... Aug 8 2025, 06:05 PM
DC_neun_vierzehn Noisy engine resolved, thanks to @BeatNavy . Issu... May 11 2026, 02:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th May 2026 - 04:10 PM |
