| airsix |
Jun 4 2003, 02:14 AM
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Had lots of requests for pictures of the hydraulic clutch conversion, so here you go.
Things that have changed since the last episode: 1) re-did the slave mount. Got rid of the stupid pulley bracket and did it right. 2) MC install was a major PITA. Had to cut a chunk out of the pan and make a mounting surface that was flat and angled in the right direction. 3) I found that there is not enough room up next to the steering rack to cut a line and re-flare it after you have discovered that you slipped the flare-nut on backwards before plumbing all the lines (ARRRRGGG!!!!). That's ok, I did a better job the second time anyway. 4) Rebuilt pedal box while I was in there (Had the bronze bushing kit laying around). Thanks Lawrenece for your comments about this last week. I almost skipped it and saved it for another time. Glad I rebuilt it. Big difference. Ok, here's the pics. (No pic from inside the car 'cuz you can't see anything with the pedal box in the way) -Ben M. Attached image(s)
| airsix |
Jun 4 2003, 02:30 AM
Parts details:
Tilton 7/8" aluminum master cyl. with remote reservoir (pitstopusa.com) CNC "pull type" slave cyl. (pitstopusa.com) Wilwood 2psi residual pressure vlave (pitstopusa.com) FLAPS brake flex hose (just some hose with 3/16" flare fittings - male on one end, fem on other) 60" stick of 3/16" steel tube (through clutch tube) 24" stick of 3/16" steel tube (from firewall to slave cyl) misc. brass fittings to connect stuff. $7 tube flaring kit from Harbor Freight slave cyl mount - fabricated from flat stock slave cly-to-clutch-fork trunion - fabbed from steel (didn't trust little plastic OEM piece) MC mount - fabricated from 14ga sheet MC linkage - (fork to attach MC pushrod to clutch pedal lever) fabricated from flat stock, a hex nut, and a steel pin w/ keeper. |
airsix Hydraulic clutch (part 2) Jun 4 2003, 02:14 AM
airsix Closer shot of the clutch MC next to the brake MC. Jun 4 2003, 02:15 AM
airsix And here's the slave with my dirty tranny in t... Jun 4 2003, 02:23 AM
914Timo Congratulations !!
Very nice pics. Good j... Jun 4 2003, 02:37 AM
Brad Roberts I need to do some digging. The MC we used in the p... Jun 4 2003, 02:41 AM
Jeroen Great job!
How do you like the "feel" of the ... Jun 4 2003, 04:12 AM
Mueller Good work Ben,
Can you attach a pressure bleeder ... Jun 4 2003, 09:51 AM
tryan excellent job. keep the heat away from the slave c... Jun 4 2003, 10:22 AM
airsix To answer some questions:
Feel: Yes, I like the ... Jun 4 2003, 10:43 AM
Gint Nice work Ben! Thanks for the pics and info.
... Jun 4 2003, 09:28 PM
airsix
914Timo Ben, did you need to do any kind of modifications ... Jun 5 2003, 01:57 AM
airsix
914Timo Many thanks Ben for shearing these information. :... Jun 6 2003, 12:02 AM
airsix
shoguneagle This is what I like about this site. Someone help... Jun 11 2003, 04:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:00 PM |
