Osnabruck914 |
Member ![]() ![]() Group: Members Posts: 164 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States ![]() |
I had to re-tap and replace one of the bolts at the front of my right a-arm today. The bolt I removed is merely marked 8.8 ML. Just curious if that is the original and proper bolt to be used there. I replaced it with a 10mm 1.5 pitch 8.8 strength 40mm length bolt- OK , I guess? I am confused by the markings on the original bolt.
Osnabruck914 |
wonkipop |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,009 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
I had to re-tap and replace one of the bolts at the front of my right a-arm today. The bolt I removed is merely marked 8.8 ML. Just curious if that is the original and proper bolt to be used there. I replaced it with a 10mm 1.5 pitch 8.8 strength 40mm length bolt- OK , I guess? I am confused by the markings on the original bolt. Osnabruck914 if you have the workshop manual its in there. Group 4 Front Axle. there is a table with descriptions. assuming bolt you question is Control Arm Forward Bearing to Body. Bolt M10 x 30 Grade 8G Torque 4.7 Mkp / 34 ftlbs |
Osnabruck914 |
Hmm 30mm... I pulled two of my existing and they are 40mm. Seem to fit alright. Osnabruck914 |
Lo-Fi Version | Time is now: 4th September 2025 - 12:46 AM |
