| axelsasso |
Jul 31 2025, 10:34 AM
Newbie ![]() Group: Members Posts: 2 Joined: 20-April 19 From: San Diego Member No.: 23,049 Region Association: None |
Like the army of 914 owners who have struggled with shifting issues, I’ve spent hours and hours trying to get my ride to shift better than a stir stick in a bucket of sand. Yes, I’ve purchased everything available in terms of replacement/upgrade parts and rebuilt from the shift knob to the transmission housing. Little by little shifts got cleaner and more predictable. I was not, however, satisfied as compared to other P cars I’ve owned or driven.
As always, I checked Tangerine Racing for any possible solutions. Talking to Chris, he suggested a newer tool that aligns the contraption from front to back. My starting point was close to acceptable as described above. Installing the tool and completing the adjustment including clean up took about 75 minutes (less if you aren’t in a hurry). It does require drilling two holes in the transmission shift plate and tapping out the holes (drill bit and tap included with the tool) but it shouldn’t scare you. This setting did the trick for me. No clipping reverse from 1st to 2nd. Cleaner engagement in 2nd through 5th. I really am happy that Chris has developed this and recommend it whether you are new to fixing your shifter, or just want to get to an end point like me. You may find a micrometer helpful, but not necessary. Also, Chris was very helpful answering the few questions I had. Hopefully, you will find this useful. 1. Drill and tap location 2. Adjustment |
| 930cabman |
Aug 5 2025, 05:34 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,714 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
My "almost daily driver" shifts ok, maybe 90%. Just purchased the kit from Chris, everything I have sourced from Tangerine is 1st class.
Thank you for being a great supplier Chris (IMG:style_emoticons/default/beerchug.gif) |
axelsasso Shift adjustment tool Jul 31 2025, 10:34 AM
ChrisFoley :thumbsup:
Can I use your picture on my instructio... Jul 31 2025, 10:55 AM
axelsasso
:thumbsup:
Can I use your picture on my instructi... Aug 1 2025, 03:10 PM
NARP74 I could never visualize how this works or what it ... Jul 31 2025, 11:24 AM
ClayPerrine
I could never visualize how this works or what it... Jul 31 2025, 11:47 AM
ChrisFoley 100% Jul 31 2025, 11:48 AM
GregAmy Another big +1. I was planning to visit Chris... Aug 1 2025, 03:43 PM
DC_neun_vierzehn @ChrisFoley , first, thank you for making a pletho... Aug 1 2025, 04:58 PM
jim_hoyland does the rubber (plastic) boot still fit to cover ... Aug 2 2025, 04:10 PM
GregAmy
does the rubber (plastic) boot still fit to cover... Aug 3 2025, 07:24 AM
mlindner Chris, just ordered one. Best, Mark Aug 3 2025, 06:53 AM
jim_hoyland Thanks, good tip. Can the holes be drilled withou... Aug 3 2025, 12:39 PM
GregAmy
Thanks, good tip. Can the holes be drilled witho... Aug 3 2025, 01:09 PM
buck toenges does this replace or make redundant your 914 Preci... Aug 10 2025, 08:57 AM
ChrisFoley In my opinion, they both serve the same purpose, s... Aug 11 2025, 03:09 AM
GregAmy I removed the pinion on the shifter adjuster up fr... Aug 11 2025, 06:36 AM
ctc911ctc Tail?
Looks like this is for a Side shifter, is t... Aug 11 2025, 06:47 AM
ChrisFoley I've had previous requests for a tailshift lin... Aug 11 2025, 07:53 AM
Chad911sc I’m having trouble finding the right shifting pl... Aug 17 2025, 07:27 PM
ChrisFoley
I’m having trouble finding the right shifting p... Aug 18 2025, 07:12 AM
GregAmy From above:
To use it, put the car in second gear... Aug 17 2025, 08:08 PM
Chad911sc Ok…makes sense. I will give it a shot once it co... Aug 18 2025, 11:04 AM
mlindner Chris...thats one slick tool. I've had my 914 ... Apr 23 2026, 02:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 20th June 2026 - 09:07 AM |
