> Fresh air blower fan
partwerks
post Aug 5 2025, 06:57 PM
Car had been sitting for a couple years, but last I recall, the fresh air blower fan worked, but now, the light comes on, but fan is not working?
Any thoughts, ideas, or suggestions?
jim_hoyland
post Aug 5 2025, 08:44 PM
Get that VIN ?
Here’s the fans inputs. Red is 12v, the other three are ground that you activate at the vent control. Do you have 12 V ?
partwerks
post Aug 5 2025, 09:24 PM
QUOTE(jim_hoyland @ Aug 5 2025, 06:44 PM) *
Don't recall if that plug is accessible from the outside? Maybe it worked loose, or not a good connection.
partwerks   Fresh air blower fan   Aug 5 2025, 06:57 PM
jim_hoyland   The light is not wired directly to the fan. The li...   Aug 5 2025, 07:04 PM
Jgilliam914   Cleaning the contacts on the sliders worked for me...   Aug 5 2025, 07:30 PM
partwerks   Cleaning the contacts on the sliders worked for m...   Aug 5 2025, 08:02 PM
dtmehall   not to rain on your parade....it could be the moto...   Aug 5 2025, 08:06 PM
jim_hoyland   Here’s the fans inputs. Red is 12v, the other th...   Aug 5 2025, 08:44 PM
partwerks   Here’s the fans inputs. Red is 12v, the other t...   Aug 5 2025, 09:24 PM
DRPHIL914   Here’s the fans inputs. Red is 12v, the other t...   Aug 11 2025, 07:46 AM
jim_hoyland   IIRC , the plug attaches to the bottom of the blow...   Aug 6 2025, 05:34 AM
RiqueMar   I know it probably sounds silly, though check the ...   Aug 6 2025, 01:31 PM
jim_hoyland   Check the fuse # 8; it powers the cig lighter, fre...   Aug 6 2025, 04:00 PM
partwerks   Tried a different relay also, but didn't work,...   Aug 7 2025, 07:12 PM
Dave_Darling   Sounds like the contacts in the sliders. --DD   Aug 7 2025, 11:16 PM
jim_hoyland   Definitely a slider issue; see if you can reach in...   Aug 8 2025, 05:49 PM
RBR53   I just did this earlier today. Remove the ash tray...   Aug 8 2025, 07:53 PM
Steve   Doesn’t help that it’s below the ash tray. Wh...   Aug 8 2025, 10:46 PM
jim_hoyland   Check these connections. Mine had a tendency to sl...   Aug 9 2025, 08:58 AM
jim_hoyland   @Dr. Phil Who sells the replacement fan motors. ?   Aug 11 2025, 12:55 PM
- Lo-Fi Version Time is now: 27th July 2026 - 08:01 AM
