RBR53 |
Newbie ![]() Group: Members Posts: 6 Joined: 1-August 25 From: Youngstown, OH Member No.: 28,902 Region Association: None ![]() |
‘75 1.8L in question. I don’t know if VW/Porsche just made a lot of varieties of fans or if there’s just an immense amount of bad information out there (probably both), but this leads me to be yet another guy confused by the TDC/Timing mark(s) on my fan. I’ve searched and searched and see no other marking on my fan besides the one shown here, a well-defined line painted red. I’m not sure if it’s supposed to represent TDC or if it’s a timing mark. I will say that I’ve been able to locate the mark on the flywheel as well, and when it is centered in the window at the top of the transmission, this mark on the fan is not showing. It’s close, but a few degrees off. That said, I found the reference photo below posted somewhere on Pelican, and the mark on my fan is in the place marked TDC in that photo. Which is to say that it’s four blades away from the wide spacer where 34 degrees is marked. Not sure if that’s gospel either, however. If anyone can offer some clarity, I’d appreciate it!
Dan Attached image(s) ![]() ![]() |
Chad911sc |
Member ![]() ![]() Group: Members Posts: 165 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States ![]() |
Also I found the easiest way to achieve this is to just jack up your passenger rear tire and place it in 5th gear. Rotate the tire by hand towards the front of the car to get it exactly where you want it, and then make your marks.
Lo-Fi Version | Time is now: 8th August 2025 - 09:41 AM |
