> Yet Another TDC/Timing Mark Question
RBR53
post Aug 4 2025, 08:45 AM
‘75 1.8L in question. I don’t know if VW/Porsche just made a lot of varieties of fans or if there’s just an immense amount of bad information out there (probably both), but this leads me to be yet another guy confused by the TDC/Timing mark(s) on my fan. I’ve searched and searched and see no other marking on my fan besides the one shown here, a well-defined line painted red. I’m not sure if it’s supposed to represent TDC or if it’s a timing mark. I will say that I’ve been able to locate the mark on the flywheel as well, and when it is centered in the window at the top of the transmission, this mark on the fan is not showing. It’s close, but a few degrees off. That said, I found the reference photo below posted somewhere on Pelican, and the mark on my fan is in the place marked TDC in that photo. Which is to say that it’s four blades away from the wide spacer where 34 degrees is marked. Not sure if that’s gospel either, however. If anyone can offer some clarity, I’d appreciate it!
Dan
emerygt350
post Aug 6 2025, 06:45 PM
Fifth gear is your friend.
I have also found a half a degree one way or the other can make a big difference. Don't take these settings as gospel. Move it around to where the engine wants it regardless of what the mark says. Much easier with a Bluetooth 123 but still very easy with a mechanical or old style 123. I don't use the fan anymore, I just go off the flywheel mark. Much easier and no questions about what it is marking.
And no chance you forget to put the cap back on the fan housing.
- Lo-Fi Version Time is now: 8th August 2025 - 09:37 AM
