> Oil in Exhaust
Mikemo44
post Aug 4 2025, 10:11 AM
Hi All, I have burnt and unburnt oil coming out of the exhaust on cylinder 2. Compression and leak down tests were both good. Looking for suggestions on how oil could be getting in/exiting the exhaust? Some searching suggests a worn exhaust valve guide?
The car doesn't have an exhaust on it, so I am able to put eyes on the exhaust port.
Thanks,
porschetub
post Aug 6 2025, 10:55 PM
QUOTE(Mikemo44 @ Aug 5 2025, 04:11 AM) *
Thanks,
What the results of both compression and leak down tests, one mans good can be others mans not so good .
Have you done a valve clearance check/reset ? ...pointless doing the above checks otherwise .
Watched the vid and that cyl is burning a lot of oil sadly hence my comment on what your results on the tests were .
Cheers.
Mikemo44
post Aug 7 2025, 08:23 AM
Compression on all 4 cylinders ranged btwn 115-123 psi. Only performed leak down on Cylinders 1 and 2, showing approx. 7-8% loss. I have checked and rechecked the valve clearances 3 or four times.
I have the engine out and waiting on a valve spring compressor tool to arrive today to take a look at the valve guides.
Appreciate the help. Will report back once I get the valve disassembled.
QUOTE(porschetub @ Aug 6 2025, 11:55 PM) *
Thanks,
Cheers.
Mikemo44
post Aug 7 2025, 12:00 PM
Quick update. I removed both exhaust and intake valves in cylinders 1 and 2. The exhaust valve in question was the only one that was difficult to remove, extremely difficult. It moved freely until the ribs at the end engaged the valve guide. I had to use a punch and hammer to get it through the guide.
There was very little play in any of the valves.
With compression good, leak down good, value guides don't appear to worn/loose, I'm not sure where to go next.
Below are a couple images, red arrow pointing to the problematic exhaust valve.
Much appreciate the feedback!
QUOTE(Mikemo44 @ Aug 7 2025, 09:23 AM) *
Thanks,
Cheers.
4 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
2 Members: jd74914, sdthomas
- Lo-Fi Version Time is now: 8th August 2025 - 10:20 AM
