| Jgilliam914 |
Aug 7 2025, 08:18 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,375 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
44IDF ...I rebuilt them (first timer) and I can't get enough fuel to flow through them. What are my next steps and who could I send them to to get them set up correctly?
| Superhawk996 |
Aug 7 2025, 10:23 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,783 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Those Venturis are ridiculously large for 2150 cc.
You need stronger vacuum signal - you should be running more like 30mm for street use. Even with 30mm Venturis 44’s hurt you bigly at initial throttle tip due to the larger butterfly’s. |
| 930cabman |
Aug 7 2025, 02:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,594 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Those Venturis are ridiculously large for 2150 cc. You need stronger vacuum signal - you should be running more like 30mm for street use. Even with 30mm Venturis 44’s hurt you bigly at initial throttle tip due to the larger butterfly’s. Ran into this exact problem with a fresh 2056 a couple years ago, just not enough volume of air. switched to 40IDF, 3 years and about 10k miles later all is very good |
Jgilliam914 getting webers to work correctly Aug 7 2025, 08:18 AM
Jgilliam914 float height was off so I will adjust this and see... Aug 7 2025, 09:15 AM
ctc911ctc According to:
https://www.performanceoriented.com... Aug 7 2025, 09:30 AM
Superhawk996
44IDF ...I rebuilt them (first timer) and I can... Aug 7 2025, 09:51 AM
Jgilliam914
44IDF ...I rebuilt them (first timer) and I can... Aug 7 2025, 09:59 AM
Superhawk996
[quote name='Superhawk996' post='3218340' date='A... Aug 7 2025, 10:04 AM
Jgilliam914
[quote name='Superhawk996' post='3218340' date='... Aug 7 2025, 10:17 AM
Chad911sc I think if I remember correctly I set mine at 10.5... Aug 7 2025, 10:00 AM
porschetub
Those Venturis are ridiculously large for 2150 cc... Aug 7 2025, 08:36 PM
brant street car with street cam?
you'll need much ... Aug 7 2025, 10:23 AM
Superhawk996 Here’s the standard venturi selection chart for ... Aug 7 2025, 10:30 AM
Superhawk996 Download the Weber tuning guide and spend some tim... Aug 7 2025, 10:33 AM
Jgilliam914
Download the Weber tuning guide and spend some ti... Aug 7 2025, 10:35 AM
VaccaRabite I had dual 44s on my 2056 for a while. 32mm vents... Aug 7 2025, 10:37 AM
DennisV
What are my next steps and who could I send them ... Aug 7 2025, 12:44 PM
NARP74 Trust the knowledge-base here. You will disagree ... Aug 7 2025, 04:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 09:09 PM |
