FL000 |
Member ![]() ![]() Group: Members Posts: 468 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California ![]() ![]() |
I’ve got a tiny bit of play in my steering, and the u-joint near the front bulkhead has some visible wear. Figure I’ll replace both of them as well as the shaft bearing and coupler. Anything else I should consider? I’m going to preorder the parts so hoping to have what I need on hand. I’ll inspect the rest when I drop the rack.
‘73 |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I’ve got a tiny bit of play in my steering, and the u-joint near the front bulkhead has some visible wear. Figure I’ll replace both of them as well as the shaft bearing and coupler. Anything else I should consider? I’m going to preorder the parts so hoping to have what I need on hand. I’ll inspect the rest when I drop the rack. ‘73 That will be interesting to see what you find as I have never seen a worn steering U joint. The rubber puck is the part that most often needs to be replaced. Nor have I seen lower steering columb bearing wear. |
Lo-Fi Version | Time is now: 22nd August 2025 - 10:41 PM |
