FL000 |
Member ![]() ![]() Group: Members Posts: 468 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California ![]() ![]() |
I’ve got a tiny bit of play in my steering, and the u-joint near the front bulkhead has some visible wear. Figure I’ll replace both of them as well as the shaft bearing and coupler. Anything else I should consider? I’m going to preorder the parts so hoping to have what I need on hand. I’ll inspect the rest when I drop the rack.
‘73 |
Jack Standz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 537 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() ![]() |
Performed a similar restoration a few months ago. Did not have "wear" in the u-joint, but it was exceptionally stiff due to a combination of 50 year-old grease and corrosion. Replaced it with a good used one from the parts stash and all is good.
If you're up to it & since you're dropping the rack, consider "rebuilding" the steering rack to reduce steering slop and improve things. Again, 50 year-old grease, etc. Started with vapor blasting the rack, cleaning old grease out, checking bearing and bushings on the ends (all good - this was a 911 rack that was in fairly good condition, which is pretty much the same as a 914 rack). Then took a piece of flat steel with sandpaper taped to it and some fine oil, to remove the grooves in the puck that slides against and puts pressure on the rack gear toward the pinion gear. Set the proper clearance with shims and put it back together with some good synthetic grease. Finish off with some 930 turbo tie rods, proper boots, spacers, etc. and you should notice the improvement. Best wishes for a successful fix. |
Lo-Fi Version | Time is now: 22nd August 2025 - 10:37 PM |
