Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,086 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
My battery was bought last month.. Alternator light comes on with the key on, but goes out at start up. Battery keeps running low and eventually won't start the car. Does this point to anything usual - VR maybe?
Literati914 |
Does this point to anything usual - VR maybe? What is the voltage directly at the battery when the car is running? I'm just getting back to this 'No charge at the Bat. and No dash light' issue. Yesterday I charged my month old battery to like 12.77, did it with only the negative cable attached.. afterwards, I disconnected the charger and didn't go back to it until today. Today I swapped out the VR for a spare one I have (they could both be bad - or both be good, I can't find any kind of continuity check etc for them). I then tightened up the belt which was maybe just slightly on the loose side. Then I checked the battery voltage before trying the starter... 12.33 now (sat overnight just the neg attached). Hooked up the pos. cable and started the car. It stayed right around 12.31V or so the while time. What else can be checked before assuming it's a bad alternator? |
Lockwodo |
Member ![]() ![]() Group: Members Posts: 226 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California ![]() ![]() |
Does this point to anything usual - VR maybe? What is the voltage directly at the battery when the car is running? I'm just getting back to this 'No charge at the Bat. and No dash light' issue. Yesterday I charged my month old battery to like 12.77, did it with only the negative cable attached.. afterwards, I disconnected the charger and didn't go back to it until today. Today I swapped out the VR for a spare one I have (they could both be bad - or both be good, I can't find any kind of continuity check etc for them). I then tightened up the belt which was maybe just slightly on the loose side. Then I checked the battery voltage before trying the starter... 12.33 now (sat overnight just the neg attached). Hooked up the pos. cable and started the car. It stayed right around 12.31V or so the while time. What else can be checked before assuming it's a bad alternator? If the battery voltage, measured at the terminals with battery not connected to car, really dropped from 12.77 to 12.33 overnight, then the battery discharged by 50% with no load on it and is defective. I would replace the battery before troubleshooting the charging system. |
Lo-Fi Version | Time is now: 29th August 2025 - 11:16 PM |
