Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,086 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
My battery was bought last month.. Alternator light comes on with the key on, but goes out at start up. Battery keeps running low and eventually won't start the car. Does this point to anything usual - VR maybe?
Literati914 |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,231 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
.. What is the battery voltage at idle? Positive terminal to chassis ground. What is the battery voltage from positive POST to the negative POST? .. Idleing: D+ double checked still showing at 13.6v Bat. + to Chassis ground = 12.49v Bat. + to Neg. bat. post = 12.49v Battery should be around 13.25V or higher with D+ at 13.6V Can you measure the battery voltage and D+ with the engine at a higher RPM? If you were getting 12.5V at the battery during operation the engine should run. You might need a helper to get the engine to 2.5-3k. |
Lo-Fi Version | Time is now: 29th August 2025 - 11:17 PM |
