> '73 PCV valve leak, High idle even after throttle body rebuild
chmillman
post Aug 12 2025, 12:35 AM
Region Association: Europe
Hi all,
So still working on the FI, have gotten a lot of stuff fixed. But, despite rebuilding the throttle body to fix an air leak around the worn shaft, the idle is still too high even with the screw turned all the way in. My FI guy did some research and found that the PCV valve is leaking. He put a constrictor clamp on the hose from the PCV valve to the intake manifold and adjusting that brought the idle down.
Apparently the configuration on the '73-'74 motors was to route the output hose of the PCV valve directly to the intiake manifold, whereas before/after the hose just went to the air cleaner. So if there is a leak in the system, it can cause idle problems - I guess that's why they changed it...?
Anyway I found this 5 year old thread here:
http://www.914world.com/bbs2/index.php?sho...c=347986&hl
Again apparently, since the original PCV valve is NLA, there was a suggestion that it be replaced with a Toyota part - haven't checked if it is still available. Is that still the current thinking? Having read the thread, I am a bit worried about the potential overpressure/underpressure problems it could cause...
Other possibility I guess would be to eliminate the PCV valve entirely and pipe the hose from the oil filler neck directly back to the air cleaner, and plug original hose entry into the intake manifold ?
Any other suggestions? TIA!
Lockwodo
post Aug 12 2025, 09:29 PM
A direct replacement, no mods needed.
chmillman   '73 PCV valve leak   Aug 12 2025, 12:35 AM
emerygt350   The active pcv (what?) is actually pretty clever. ...   Aug 12 2025, 07:01 AM
Lockwodo   I installed a FRAM FV279 PCV valve in my '74 2...   Aug 12 2025, 08:08 AM
emerygt350   I installed a FRAM FV279 PCV valve in my '74 ...   Aug 12 2025, 01:53 PM
Lockwodo   I installed a FRAM FV279 PCV valve in my '74...   Aug 12 2025, 04:56 PM
emerygt350   [quote name='emerygt350' post='3219026' date='Aug...   Aug 12 2025, 06:39 PM
Ishley   I did the Toyota PCV valve and it works well. I o...   Aug 12 2025, 02:17 PM
Ishley   Amazon for the grommet.   Aug 12 2025, 06:58 PM
emerygt350   No modifications needed?   Aug 12 2025, 06:59 PM
Lockwodo   A direct replacement, no mods needed.   Aug 12 2025, 09:29 PM
emerygt350   Interesting! I might give it a go and see wha...   Aug 13 2025, 04:55 PM
JamesM   IF you go the route of open venting the crank case...   Aug 13 2025, 08:35 PM
chmillman   We've decided to go with the Toyota substitute...   Aug 14 2025, 10:15 AM
emerygt350   We've decided to go with the Toyota substitut...   Aug 14 2025, 01:44 PM
emerygt350   and did you make sure it is actually the pcv?   Aug 14 2025, 01:45 PM
chmillman   Well, we tried to find a Fram 279 equivalent. Thi...   Aug 14 2025, 03:26 PM
Ishley   This is what I have and it works good for me. I a...   Aug 14 2025, 04:18 PM
emerygt350   I know I had a conversation with one of the old ha...   Aug 14 2025, 04:41 PM
Ishley   I don’t disagree. I would love a good stock one....   Aug 14 2025, 07:43 PM
- Lo-Fi Version Time is now: 16th August 2025 - 10:54 AM
